StarTech.com M.2 NVMe PCIe SSD Enclosure - IP67 water/dust resistance
Quicklinx: FTWYWS00 Mfr#: M2E1BRU31C
Type: Storage enclosure
HD Size: M.2
Power Supply: [N/A]
10 In Stock
£73.29 ex VAT
£87.94 inc VAT
This rugged M.2 NVMe PCIe SSD enclosure is a highly portable, high-performance data storage solution for your USB-C or Thunderbolt 3 enabled devices.
  • Unparalleled Performance
    Leverage the high speeds of your M.2 NVMe drive, with this external SSD enclosure. It delivers USB 3.1 Gen 2 read/write speeds up to 10Gbps, nearly twice the capability of traditional M.2 SATA and hard drive enclosures. This fan-less solid aluminum enclosure features an internal thermal pad that transfers heat away from the drive for maximum heat dissipation, ensuring your drive operates noiselessly at an optimal temperature to preserve performance.
  • Dustproof and Water Resistant
    Be prepared for the unexpected. The enclosure for PCI Express based NVMe SSDs comes with an IP67 rating, which means that it's both dustproof and water resistant. It's the perfect solution for people who work outside. Or, for people who work in environments with a lot of dust, like: construction sites, factories, or manufacturing facilities.
  • Broad Compatibility
    The USB 3.1 Gen 2 NVMe enclosure works with tablets, laptops, desktop computers and hosts that are equipped with USB Type-C and Thunderbolt 3 ports. It's also backward compatible with USB 3.1 Gen 1, making it a convenient solution for the office or other environments.
  • The Choice of IT Pros Since 1985
    StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales. M2E1BRU31C is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com USB-C 10Gbps M.2 NVMe PCIe SSD Enclosure, Rugged Aluminum External M.2 PCIe M-Key Case IP67 Rated, 1GB/s Read/Write, Supports 2230/2242/2260/2280, TB3 Compatible, Mac/PC - 1.6ft USB-C Cable Incl - storage enclosure - M.2 Card - USB 3.2 (Gen 2)
Storage enclosure - external
Bus Type
USB 3.2 (Gen 2)
Expansion Bays
1 x internal - M.2 2230/2242/2260/2280
Hard Drive Form Factor Compatibility
M.2
M.2 Card
Data Transfer Rate
10 Gbit/s
Supported Devices
Solid state drive
Max Storage Devices Qty
1
Product Material
Aluminium
10.5 cm x 4.5 cm x 1.4 cm
100 g
P/N: PEXUSB321C
M.2
Host Bus
USB 3.2 (Gen 2)
Product Material
Aluminium
Storage Controller
M.2 Card
Data Transfer Rate
10 Gbit/s
Supported Devices
Solid state drive
1
JMicron JMS583
Bays
1 x PCIe 3.0 - M.2 NGFF M Key
1 x USB 3.2 (Gen 2) - 24 pin USB-C
Screwdriver, rubber feet, drive mounting stand-off
1 x USB-C cable - external - 5 cm
UASP transfer protocol, bus powered, 4Kn drive compatible
MTBF
50,000 hours
FCC, RoHS, WEEE, REACH
10.5 cm
4.5 cm
1.4 cm
100 g
Shipping Width
17 cm
Shipping Depth
14 cm
Shipping Height
3 cm
Shipping Weight
220 g
5 °C
35 °C
20 - 80%
P/N: PEXUSB321C
FTWY StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £10.98
FTWY StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £14.29
FTWY StarTech.com 0.5m USB C Cable - USB 3.1 In Stock £15.66
FTWY StarTech.com 0.5m USB to USB-C Cable 10Gbps In Stock £9.39
FTWY StarTech.com 4x M.2 PCIe to TB3 Enclosure In Stock £341.51
HD Size: M.2
Power Supply: [N/A]
