Mount a solid state drive into your desktop computer, using a standard SATA host connection. The SAT32MSATPEX M.2 to SATA adapter lets you connect a SATA M.2 (NGFF) SSD to a standard SATA port, and mount the drive into any desktop expansion slot.
Now, you can greatly increase the performance of your desktop computer by replacing your platter drive with a fast M.2 NGFF solid state drive. By installing your primary operating system on the M.2 SSD drive and using your higher-capacity platter HDD for bulk storage, you can harness the speedy performance of the M.2 drive for frequently accessed data while storing files you access less often on your platter drive.
For a hassle-free installation, the adapter mounts into any new or legacy desktop expansion slot, with support for AGP, PCI, and PCIe slots. The adapter also includes full-profile and low-profile brackets, ensuring compatibility with both full-sized and small form factor desktops.
- StarTech.com M.2 to SATA Expansion Slot Mounted SSD Adapter - NGFF Solid State Drive to SATA Converter - PCI or PCI-express Slot Mounted (S32M2NGFFPEX) - storage controller (RAID) - SATA 6Gb/s - SATA 6Gb/s
- Storage controller (RAID) - internal
- Bus Type
- SATA 6Gb/s
- Compatible Bay
- 1
- Hard Drive Form Factor Compatibility
- M.2
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Solid state drive
- 12 cm x 9.5 cm x 1.8 cm
- 130 g
- 2-year warranty
- M.2
- Host Bus
- SATA 6Gb/s
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- Solid state drive
- 1 x M.2 Card - M.2 Card
- Connections
- 1 x SATA 6Gb/s - 22 pin Serial ATA
- Compatible Bay
- 1 x internal
- Included Accessories
- Low-profile bracket, screwdriver, 1 x screw
- FCC, RoHS
- Limited warranty - 2 years
- 12 cm
- 9.5 cm
- 1.8 cm
- 130 g
- 0 °C
- 50 °C
- 5 - 95%
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £5.06 |
StarTech.com 24" Serial ATA Cable | In Stock | £5.28 |
StarTech.com 18" Serial ATA Cable w/R Angle | In Stock | £5.00 |
StarTech.com 18in SATA Serial ATA Cable | In Stock | £2.45 |
StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable | In Stock | £5.50 |
StarTech.com 12in Latching SATA Cable | In Stock | £6.16 |
StarTech.com SATA to LP4 Power Cable Adapter | In Stock | £3.72 |
StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F | In Stock | £6.34 |
StarTech.com 12in SATA Serial ATA Cable | In Stock | £5.00 |
StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F | In Stock | £6.16 |
StarTech.com 12in LP4 to 2x Latching SATA Power Y Cable Splitter Adapter - 4 Pin Molex to Dual SATA | In Stock | £5.50 |
StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F | In Stock | £5.60 |
StarTech.com M.2 SATA external SSD enclosure USB 3.0 with UASP | In Stock | £19.88 |
StarTech.com 2x M.2 SSD Controller - PCIe | In Stock | £21.26 |
StarTech.com M.2 SATA Enclosure with USB-C | In Stock | £25.86 |
StarTech.com 6" SATA Power Y Splitter Cable | In Stock | £6.34 |
StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter | In Stock | £18.76 |
StarTech.com U.2 to PCIe Adapter -SFF-8639 | In Stock | £27.51 |
StarTech.com M.2 to U.2 Adapter | In Stock | £24.18 |
StarTech.com x8 Dual M.2 PCI Express SSD Adapter - PCIe 3.0 for PCIe NVMe | In Stock | £135.47 |
StarTech.com M.2 SSD Enclosure for M.2 SATA Drives - USB 3.1 - USB C M.2 | In Stock | £29.33 |
