This high quality SATA cable is designed for connecting SATA drives even in tight spaces. The SATA18 Serial ATA Cable features two 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
- StarTech.com 18in SATA Serial ATA Cable - 18in SATA Cable - 18 SATA Cable - 18in Serial ata Cable - SATA cable - 45.8 cm
- SATA cable
- Length
- 45.8 cm
- Connector
- 7 pin Serial ATA - female
- Connector (Second End)
- Limited lifetime warranty
- Designed For
- P/N: 10P6G-PCIE-SATA-CARD, 25S22M2NGFFR, 25SAT22MSAT, 25SAT35HDD, 2P6G-PCIE-SATA-CARD, 35S24M2NGFF, 4P6G-PCIE-SATA-CARD, 6P6G-PCIE-SATA-CARD, BRACKET25SAT, IDE2SAT25, PATA2SATA3, PEXSAT32, S322M225R, S32M2NGFFPEX, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, SAT32MSATPEX, ST521PMINT, USB3SSATAIDE
- Storage Cable Type
- SATA cable
- Length
- 45.8 cm
- Connector
- Designed For
- P/N: 10P6G-PCIE-SATA-CARD, 25S22M2NGFFR, 25SAT22MSAT, 25SAT35HDD, 2P6G-PCIE-SATA-CARD, 35S24M2NGFF, 4P6G-PCIE-SATA-CARD, 6P6G-PCIE-SATA-CARD, BRACKET25SAT, HSB220SAT25B, IDE2SAT25, PATA2SATA3, PEXSAT32, PEXSATA22I, S322M225R, S32M2NGFFPEX, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, SAT32MSATPEX, ST521PMINT, USB2SATAIDE, USB3SSATAIDE
