StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter
Quicklinx: 9CS7WS00 Mfr#: SAT32M225
15 In Stock
£15.54 ex VAT
£18.64 inc VAT
Convert an M.2 NGFF SSD into a 7mm high 2.5in SATA 6Gbps Open Frame SSD. Vastly increase system performance by adding the speed of an M.2 SSD (Next Generation Form Factor) in any 2.5" SATA application, with the SAT32M225 M.2 SSD to SATA adapter.
Utilize the full potential of your SATA III controller, with an M.2 SSD reducing your data transfer bottleneck with file transfer speeds up to 6 Gbps. M.2 SSDs can also save you money by reducing your power consumption over regular platter drives.
Help protect the health of your drive with an open-frame design that maximizes heat dissipation.
StarTech.com M.2 SATA SSD to 2.5in SATA Adapter - M.2 NGFF to SATA Converter - 7mm - Open-Frame Bracket - M2 Hard Drive Adapter (SAT32M225) - storage controller - SATA 6Gb/s - SATA 6Gb/s
Storage controller - internal
Bus Type
SATA 6Gb/s
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Channel Qty
1
7 cm x 10 cm x 0.7 cm
40 g
P/N: BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F, SATDOCK5U3ER, SATERASER4, SDOCK1EU3P, SDOCK1EU3P2, SDOCK4U313, SDOCKU313, SDOCKU313E, USB312SAT3, USB31C2SAT3, USB31CSAT3CB
Host Bus
SATA 6Gb/s
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Channel Qty
1
No CPU
1 x SATA 6Gb/s - SATA power
1 - M.2 Card
Not compatible with M.2 NVMe or AHCI PCI-Express SSDs
Mounting Kit
Included
FCC, RoHS
7 cm
10 cm
0.7 cm
40 g
-40 °C
85 °C
9CS7 StarTech.com 24" Serial ATA Cable In Stock £5.16
9CS7 StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
9CS7 StarTech.com 18in SATA Serial ATA Data and Power Combo Cable In Stock £5.78
9CS7 StarTech.com 18in SATA Serial ATA Cable In Stock £2.51
9CS7 StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter In Stock £4.06
9CS7 StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable In Stock £5.36
9CS7 StarTech.com 12in Latching SATA Cable In Stock £5.50
9CS7 StarTech.com 12in SATA Serial ATA Cable In Stock £4.46
9CS7 StarTech.com 6in SATA to LP4 Power Cable Adapter - F/M In Stock £5.79
9CS7 StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F In Stock £6.16
9CS7 StarTech.com 6in SATA to Left Angle SATA Serial ATA Cable In Stock £3.92
9CS7 StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket In Stock £7.12
9CS7 StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £15.54
9CS7 StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £17.99
9CS7 StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter In Stock £14.65
9CS7 StarTech.com M.2 NGFF to SATA Adapter In Stock £20.24
9CS7 StarTech.com 2x M.2 SSD Controller - PCIe In Stock £21.26
9CS7 StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter In Stock £18.59
9CS7 StarTech.com 3PT M.2 SSD Card - PCIe 3.0 In Stock £28.29
9CS7 StarTech.com M.2 SATA Raspberry Pi Adapter In Stock £19.02
9CS7 StarTech.com U.2 to PCIe Adapter -SFF-8639 In Stock £31.05
9CS7 StarTech.com M.2 to U.2 Adapter In Stock £22.89
9CS7 StarTech.com x8 Dual M.2 PCI Express SSD Adapter - PCIe 3.0 for PCIe NVMe In Stock £129.01
9CS7 StarTech.com 18in Right Angle SATA Cable In Stock £4.22
