StarTech.com U.2 to PCIe Adapter -SFF-8639
Quicklinx: CZCDWS00 Mfr#: PEX4SFF8639
More than 50 In Stock
£27.51 ex VAT
£33.01 inc VAT
Get ultra-fast data access by adding an NVMe U.2 SSD to your computer. This U.2 to PCIe adapter lets you add a high-speed, U.2 NVMe SSD to a PC with an available PCI Express expansion slot. You can mount the PCIe U.2 drive directly onto the adapter, giving you an easy and convenient way to improve your system performance and expand overall internal storage.
  • Boost your system speed and performance
    The expansion card lets you take full advantage of the fast performance and compact size of PCIe U.2 internal solid-state drives. The adapter connects directly to your computer motherboard to support an NVMe U.2 PCIe-based SSD through ultra-fast PCIe. With the U.2 PCIe-based drive in place, the adapter gives your computer a significant speed boost.
  • Easy to install
    The expansion card is equipped with a full-profile bracket and doesn't require an adapter cable for installation, this helps to reduce clutter and simplifies system builds.
StarTech.com U.2 to PCIe Adapter - x4 PCIe - For 2.5" U.2 NVMe SSD - SFF-8639 PCIe Adapter - U.2 SSD - PCIe SSD - U.2 drive (PEX4SFF8639) - interface adapter - Ultra M.2 Card - PCIe 3.0 x4
Interface adapter - plug-in card
Bus Type
PCIe 3.0 x4
Red
Hard Drive Form Factor Compatibility
2.5"
Ultra M.2 Card
Supported Devices
Solid state drive
Max Storage Devices Qty
1
2.2 cm x 16.5 cm x 12.2 cm
65 g
P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16, U2M2E125
2.5"
Hard Drive Maximum Height
15 mm
Host Bus
PCIe 3.0 x4
Red
Storage Controller
Ultra M.2 Card
Supported Devices
Solid state drive
1
1 x Ultra M.2 Card - U.2 (SFF-8639)
1 x PCIe 3.0
Supports NVM Express
2.2 cm
16.5 cm
12.2 cm
65 g
5 °C
50 °C
15 - 90%
CZCD StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £15.57
CZCD StarTech.com M.2 SATA external SSD enclosure USB 3.0 with UASP In Stock £19.88
CZCD StarTech.com 2x M.2 SSD Controller - PCIe In Stock £21.26
CZCD StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter In Stock £18.76
CZCD StarTech.com U.2 to PCIe Adapter -SFF-8639 In Stock £27.51
CZCD StarTech.com M.2 to U.2 Adapter In Stock £23.11
CZCD StarTech.com M.2 NVMe SSD Enclosure for PCIe SSDs - USB 3.1 Gen 2 Type-C In Stock £40.35
CZCD StarTech.com USB PCIE/SATA M.2 Enclosure In Stock £45.80
CZCD StarTech.com U.3 to PCIe Adapter Card In Stock £33.39
