StarTech.com LP4 to SATA Power Cable Adapter with Floppy Power
Quicklinx: 4MJDWS00 Mfr#: LP4SATAFMD
Length: 0.15m
Type: Power
£5.44 ex VAT
£6.52 inc VAT
This LP4 to SATA Power Adapter Cable features an LP4 female connector as well as an SP4 female power connector and a SATA power connector, allowing you to connect an IDE hard drive as well as a floppy disk drive to a Serial ATA power connector provided by the computer power supply. This high quality LP4/SATA power adapter cable is expertly designed for durability.
StarTech.com LP4 to SATA Power Cable Adapter with Floppy Power - power adapter
Power adapter
Connectors
15 pin Serial ATA power - male
Connectors (Second End)
4 PIN internal power - female , 4 PIN mini-power connector - female
P/N: SATSASBAY425, ATX2POWER430, ATX2POWER530, DRW110SATBK
Power adapter
Connectors
StarTech.com 4 Drive 2.5in Removable SAS SATA Mobile Rack Backplane, 430 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC, 530 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC
4MJD StarTech.com LP4 to SATA Power Cable Adapter with Floppy Power In Stock £5.44
4MJD StarTech.com SATA to LP4 Power Cable Adapter with 2 Additional LP4 In Stock £4.53
4MJD StarTech.com 6in LP4 to LP4 SATA Power Y Cable Adapter In Stock £3.30
Length: 0.15m
Type: Power
Price Range Ex VAT: 0 - 50
