StarTech.com LP4 to SATA Power Cable Adapter with Floppy Power
Quicklinx: 4MJDWS00 Mfr#: LP4SATAFMD
This LP4 to SATA Power Adapter Cable features an LP4 female connector as well as an SP4 female power connector and a SATA power connector, allowing you to connect an IDE hard drive as well as a floppy disk drive to a Serial ATA power connector provided by the computer power supply. This high quality LP4/SATA power adapter cable is expertly designed for durability.
StarTech.com LP4 to SATA Power Cable Adapter with Floppy Power (LP4SATAFMD) - power adapter
Power adapter
Connectors
15 pin Serial ATA power - male
Connectors (Second End)
4 PIN internal power - female , 4 PIN mini-power connector - female
P/N: DRW110SATBK, PEX2M2, PEXM2SAT3422, S251BU31REM, S25SLOTR, SATSASBP425
Power adapter
Connectors
4MJD StarTech.com SATA to LP4 Power Cable Adapter with 2 Additional LP4 In Stock £3.10
