StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F
Quicklinx: 7B7HWS00 Mfr#: SATA18LA1
Length: 46cm
Type: SATA
£6.16 ex VAT
£7.39 inc VAT
Make a left-angled connection to your SATA drive, for installation in tight spaces. The SATA18LA1 Left Angle (90-degree) SATA Cable features a standard (straight) SATA receptacle as well as a left-angled SATA receptacle, providing a simple 18-inch connection to a Serial ATA drive, with full SATA 3.0 bandwidth support of up to 6Gbps when used with SATA 3.0 compliant drives.
The left-angled SATA connection enables you to plug in your Serial ATA hard drive in hard to reach areas or tight spaces, while the low profile and flexible design of the cable improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
As an alternative, StarTech.com also offers an 18in Right Angle SATA cable (SATA18RA1), which provides the same simple installation as this left angled SATA cable, but allows the cable to connect to the SATA drive from the opposite direction.
StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F (SATA18LA1) - SATA cable - 46 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Shielded
Left-angled connector
Length
46 cm
Connector
7 pin Serial ATA - receptacle
Connector (Second End)
Red
P/N: 25S22M2NGFFR, 25SAT22MSAT, 35S24M2NGFF, CFAST2SAT25, MSAT2SAT3, PEXESAT322I, PEXM2SAT32N1, S322M225R, S32M2NGFFPEX, SAT2M2NGFF25, SAT2MSAT25, SAT32M225, SAT32MSAT257, SAT32MSATM, SAT32MSATPEX, USB2SATAIDE, USB3SSATAIDE
Storage Cable Type
SATA cable
Interface Speed
Shielded
Shielding Material
Length
46 cm
Red
Connector
RoHS
7B7H StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
7B7H StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F In Stock £6.16
Length: 46cm
Type: SATA
