Connect two LP4 peripheral devices (CD/DVD-ROM drives etc.) to a single LP4 connector. The PYO2L LP4 to 2x LP4 power Y splitter cable features one LP4 male connector that breaks out into two LP4 female connectors, providing a cost-effective solution for connecting two LP4 peripheral devices (CD/DVD-ROM drives, IDE hard drives etc.) to a single LP4 connector provided by the computer power supply.
- StarTech.com LP4 to 2x LP4 Power Y Splitter Cable M/F - LP4 Splitter - Molex Y Splitter - Molex Splitter (PYO2L) - power cable - 4 PIN internal power to 4 PIN internal power - 0.2 m
- Power cable
- Length
- 0.2 m
- Connector
- 2 x 4 PIN internal power - female
- Connector (Second End)
- 4 PIN internal power - male
- Limited lifetime warranty
- Designed For
- P/N: ATX2POWER350, ATX2POWER400, ATX2POWER450, ATX2POWR350E, ATX2POWR400E, ATX2PW400PRO, ATX2PW450PRO, ATX2PW500PRO, ATX2PW550PRO, ATXPOW250PRO, ATXPOW300PRO, ATXPOW350DF, ATXPOW400DF, ATXPOWER250, ATXPOWER300, ATXPOWER300B, FAN5X1TX3, HSB225S3R, IDE2SAT2, MICATXPOW145, S25SLOTR, SATSASBP425
- Power cable
- Length
- 0.2 m
- Connector
- Designed For
- P/N: ATX2POWER350, ATX2POWER400, ATX2POWER450, ATX2POWR350E, ATX2POWR400E, ATX2PW400PRO, ATX2PW450PRO, ATX2PW500PRO, ATX2PW550PRO, ATXPOW250PRO, ATXPOW300PRO, ATXPOW350DF, ATXPOW400DF, ATXPOWER250, ATXPOWER300, ATXPOWER300B, FAN5X1TX3, HSB225S3R, IDE2SAT2, MICATXPOW145, PS2POWER230, S25SLOTR, SATSASBP425
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £4.48 |
StarTech.com LP4 to 2x LP4 Power Y Splitter Cable M/F | In Stock | £4.25 |
StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter | In Stock | £4.16 |
StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F | In Stock | £7.38 |
StarTech.com 6in SATA to LP4 Power Cable Adapter - F/M | In Stock | £5.67 |
StarTech.com 12in LP4 to 2x Latching SATA Power Y Cable Splitter Adapter - 4 Pin Molex to Dual SATA | In Stock | £5.12 |
StarTech.com 12in LP4 to 2x Right Angle Latching SATA Power Y Cable Splitter - 4 Pin Molex to SATA | In Stock | £4.30 |
StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F | In Stock | £5.40 |
StarTech.com 12in Molex LP4 Power Extension Cable – M/F | In Stock | £4.34 |
StarTech.com 6" SATA Power Y Splitter Cable | In Stock | £7.38 |
