Power two SATA drives from a single LP4 power supply connector. The PYO2LP4LSATA LP4 Molex to Dual Latching SATA power splitter cable features two Serial ATA female power connectors and one LP4 male connector - a reliable solution that enables you to power two SATA drives using a single LP4 connection to the computer power supply.
This durable LP4 to SATA Y cable adapter is 12 inches in length, giving you enough cable slack to position drives as needed within the computer case, while saving the cost and hassle of upgrading a power supply for compatibility with Serial ATA drives.
- StarTech.com 12in LP4 to 2x Latching SATA Power Y Cable Splitter Adapter - 4 Pin LP4 to Dual SATA Y Splitter - power adapter - 4 PIN internal power to SATA power - 30 cm
- Power adapter
- Latched
- Length
- 30 cm
- Connector
- 4 PIN internal power - male
- Connector (Second End)
- 2 x 15 pin Serial ATA power - female
- Limited lifetime warranty
- Designed For
- P/N: 35S24M2NGFF, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB3SATSASBA, HSB43SATSASB, HSB4SATSASBA, S32M2NGFFPEX, SAT32MSATPEX
- Power adapter
- American Wire Gauge (AWG)
- 20
- Latched
- Length
- 30 cm
- Connector
- RoHS
- Designed For
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £4.60 |
StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter | In Stock | £4.26 |
StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F | In Stock | £6.64 |
StarTech.com 6in 4 Pin Molex to Right Angle SATA Power Cable Adapter | In Stock | £5.00 |
StarTech.com 12in LP4 to 2x Latching SATA Power Y Cable Splitter Adapter - 4 Pin Molex to Dual SATA | In Stock | £4.22 |
StarTech.com 6" SATA Power Y Splitter Cable | In Stock | £6.64 |
