StarTech.com LP4 to 2x LP4 Power Y Splitter Cable M/F
Quicklinx: 3ZLMWS00 Mfr#: PYO2L
Type: Power
£4.37 ex VAT
£5.24 inc VAT
Connect two LP4 peripheral devices (CD/DVD-ROM drives etc.) to a single LP4 connector. The PYO2L LP4 to 2x LP4 power Y splitter cable features one LP4 male connector that breaks out into two LP4 female connectors, providing a cost-effective solution for connecting two LP4 peripheral devices (CD/DVD-ROM drives, IDE hard drives etc.) to a single LP4 connector provided by the computer power supply.
  • Efficient power distribution
    The LP4 to 2x LP4 Power Y Splitter Cable M/F enables efficient distribution of power by splitting a single LP4 power connection into two, allowing for the simultaneous powering of two internal devices.
  • Durable design
    Crafted for longevity, this Molex Y Splitter is designed to withstand the rigors of daily use, ensuring a reliable connection between your PC's power supply and internal components.
  • Compatibility assured
    Designed specifically for PC use, this cable ensures compatibility with a wide range of internal power configurations, making it a versatile addition to any setup.
StarTech.com LP4 to 2x LP4 Power Y Splitter Cable M/F - LP4 Splitter - Molex Y Splitter - Molex Splitter (PYO2L) - power cable - 4 PIN internal power to 4 PIN internal power - 0.2 m
Power cable
Length
0.2 m
Connector
2 x 4 PIN internal power - female
Connector (Second End)
4 PIN internal power - male
P/N: ATX2POWER350, ATX2POWER400, ATX2POWER450, ATX2POWR350E, ATX2POWR400E, ATX2PW400PRO, ATX2PW450PRO, ATX2PW500PRO, ATX2PW550PRO, ATXPOW250PRO, ATXPOW300PRO, ATXPOW350DF, ATXPOW400DF, ATXPOWER250, ATXPOWER300, ATXPOWER300B, FAN5X1TX3, HSB225S3R, IDE2SAT2, MICATXPOW145, S25SLOTR, SATSASBP425
Power cable
Length
0.2 m
Connector
P/N: ATX2POWER350, ATX2POWER400, ATX2POWER450, ATX2POWR350E, ATX2POWR400E, ATX2PW400PRO, ATX2PW450PRO, ATX2PW500PRO, ATX2PW550PRO, ATXPOW250PRO, ATXPOW300PRO, ATXPOW350DF, ATXPOW400DF, ATXPOWER250, ATXPOWER300, ATXPOWER300B, FAN5X1TX3, HSB225S3R, IDE2SAT2, MICATXPOW145, PS2POWER230, S25SLOTR, SATSASBP425
3ZLM StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £5.06
3ZLM StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter In Stock £4.48
3ZLM StarTech.com 6in SATA to LP4 Power Cable Adapter - F/M In Stock £6.06
3ZLM StarTech.com 12in LP4 to 2x Latching SATA Power Y Cable Splitter Adapter - 4 Pin Molex to Dual SATA In Stock £5.50
3ZLM StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F In Stock £5.60
Type: Power
