Add a 25-pin parallel port to the back of your low profile/small form factor computer from your motherboard. The PLATE25F16LP DB25 to IDC26 Parallel Port Bracket adds a DB25 parallel port to the rear panel of a low profile/small form factor computer, which connects to an IDC26 header connector on the motherboard.
Constructed of only top quality components, the Parallel Port Header Cable offers a cost-effective solution for adding a parallel device connection using a compatible motherboard.
- StarTech.com Low Profile 16in Parallel Port Header Cable Adapter w/ Bracket - parallel panel - 40.64 cm
- Parallel panel
- Low profile
- Length
- 40.64 cm
- Connector
- 25 pin D-Sub (DB-25) - female
- Connector (Second End)
- 26 PIN IDC - female
- Grey
- Limited lifetime warranty
- Parallel panel
- American Wire Gauge (AWG)
- 28
- Low profile
- Length
- 40.64 cm
- Grey
- Connector
