StarTech.com 16in DB25 Parallel Female to IDC 25 Pin Header Slot Plate
Quicklinx: 7TGTWS00 Mfr#: PLATE25F16
Length: 40.64cm
Hurry, only 1 left in stock!
£5.48 ex VAT
£6.57 inc VAT
Add an extra parallel port to the back of your PC from your motherboard. This 25-pin Parallel to 25-pin Header Slot Plate features one DB25 Female connector and one IDC 25 connector.
Constructed of only top quality components, the Parallel Slot Plate adapter offers a cost-effective solution for adding a Parallel device connection using a compatible motherboard.
  • Reliable Connection
    This adapter features a DB25 female connector that supports a robust connection, making it suitable for connecting different peripherals and legacy equipment.
  • Flexible Length
    At 16 inches, this cable provides flexibility in installation, allowing users to accommodate various setups without compromising on reach.
  • Exceptional Durability
    Constructed with 28 AWG wiring, this product is built to withstand regular use and ensures long-lasting connections for all devices.
StarTech.com 16in DB25 Parallel Female to IDC 25 Pin Header Slot Plate (PLATE25F16) - parallel panel - DB-25 to 26 PIN IDC - 40.64 cm
Parallel panel
Length
40.64 cm
Connector
25 pin D-Sub (DB-25) - female
Connector (Second End)
26 PIN IDC - female
Grey
Parallel panel
American Wire Gauge (AWG)
28
Length
40.64 cm
Grey
Connector
26 PIN IDC - female
7TGT StarTech.com Low Profile 16in Parallel Port Header Cable Adapter with Bracket – DB25 (F) to IDC26 In Stock £5.07
Length: 40.64cm
