StarTech.com Low Profile 16in Parallel Port Header Cable Adapter with Bracket – DB25 (F) to IDC26
Quicklinx: 8CP5WS00 Mfr#: PLATE25F16LP
Length: 40.64cm
24 In Stock
£5.68 ex VAT
£6.81 inc VAT
Add a 25-pin parallel port to the back of your low profile/small form factor computer from your motherboard. The PLATE25F16LP DB25 to IDC26 Parallel Port Bracket adds a DB25 parallel port to the rear panel of a low profile/small form factor computer, which connects to an IDC26 header connector on the motherboard.
Constructed of only top quality components, the Parallel Port Header Cable offers a cost-effective solution for adding a parallel device connection using a compatible motherboard.
StarTech.com Low Profile 16in Parallel Port Header Cable Adapter w/ Bracket - DB25 to IDC26 Parallel Port Bracket DB-25 (F) to IDC 26 (F) (PLATE25F16LP) - parallel panel - DB-25 to 26 PIN IDC - 40.64 cm
Parallel panel
Low profile
Length
40.64 cm
Connector
25 pin D-Sub (DB-25) - female
Connector (Second End)
26 PIN IDC - female
Grey
Parallel panel
American Wire Gauge (AWG)
28
Low profile
Length
40.64 cm
Grey
Connector
26 PIN IDC - female
8CP5 StarTech.com 16in DB25 Parallel Female to IDC 25 Pin Header Slot Plate In Stock £5.46
Length: 40.64cm
