StarTech.com Laptop Stand - 2-in-1 Riser/Vertical Stand
Quicklinx: GBTHWS00 Mfr#: LTSTND2IN1
Device Type: Laptop, Ultrabook, Macbook
Type: Laptop Stand
Device Screen Size: 11 - 15
Colour: Silver
12 In Stock
£25.60 ex VAT
£30.72 inc VAT
Laptop Riser Stand Tilted and Vertical Mount Options For Ultra-thin Laptops 11" to 15". This 2 in 1 Aluminum Laptop Stand enables you to mount your laptop in two different positions depending on your application. Its aesthetic design provides function while maintaining an elegant silver look that matches your MacBook or other ultra-thin laptops. The 2 interchangeable silicone holders allow this stand to support laptops from 11" to 15" (14mm to 16mm in thickness) in an upright position, while protecting them from scratches and scuffing.
Ergonomic design
This Laptop Stand provides you with two options for mounting your laptop to suit your desktop setup. Use it as a laptop tilted stand, giving you an ergonomic tilted position for your laptop (17°); or as a vertical laptop stand, to save space and keep your workstation organized. With the included bracket, this stand provides increased stability and weight distribution to your vertically mounted laptop.
Increased Airflow
With its open frame, this Laptop Riser Stand offers increased airflow allowing your devices to stay cooler than if they were laying flat on your desk.
Port Accessibility
The Aluminum Laptop stand has been designed with an open frame design, so you can have all the ports on your laptop easily accessed to use with docking stations, and other peripherals in both mounting options.
The LTSTND2N1 is backed by a StarTech.com 5-year warranty and free lifetime technical support.
  • Ergonomic design
  • Increased airflow
    With its open frame, this Laptop Riser Stand offers increased airflow allowing your devices to stay cooler than if they were lying flat on your desk.
  • Port accessibility
StarTech.com Laptop Stand, 2-in-1 Laptop Riser Stand or Vertical Stand, Ideal for Ultrabooks & MacBook Pro/Air up to 15", Ergonomic Angled Notebook Holder for Office Desk, Silver, Aluminum - Elevated Laptop Stand - notebook stand
Notebook stand
Placing / Mounting
Desktop
Package Content
Rubber covers, QSG, stability bracket, notebook riser
Silver
Product Material
Aluminium
16.7 cm x 23.3 cm x 7.3 cm
540 g
Notebook Compatibility
15"
Notebook Supported Sizes
11" - 15" / 27.9 cm - 38.1 cm
5-year warranty
Notebook stand
Placing / Mounting
Desktop
Product Material
Aluminium
Package Content
16.7 cm
23.3 cm
7.3 cm
540 g
22 cm x 23.8 cm x 8 cm / 540 g
15"
Silver
RoHS, WEEE
Limited warranty: - 5 years
GBTH StarTech.com 15in Laptop Privacy Screen - Matte or Glossy - 16:9 Ratio In Stock £32.40
GBTH StarTech.com 13in Laptop Privacy Screen - 16:10 Aspect Ratio In Stock £33.45
GBTH StarTech.com Laptop Riser Stand, Ergonomic In Stock £29.78
Device Type: Laptop
Device Type: Ultrabook
Device Type: Macbook
Type: Laptop Stand
Colour: Silver
