Adjust the viewing angle of a laptop's base panel/keyboard, using this laptop riser stand. Featuring a collapsible frame with adjustable width, this stand supports smaller phones/tablets as well as portable monitors, and laptops with screen sizes of up to 15.6". The stand is capable of supporting devices of up to 22lb (10kg).
                Tilted for Ideal ViewingThe ergonomic laptop stand features 9 different angle adjustments (15° / 27° / 37° / 45° / 52° / 60° / 67° / 75° / 84°) to help find the most comfortable viewing angle. The raised lip at the front and the anti-slip rubber pads prevent the laptop from shifting while making adjustments and during operation. In addition, the pads protect the mounted device from cosmetic damage.
                Collapsible DesignThe ultra-lightweight (0.73lb / 329g) collapsible stand is ideal for users who require a stand that is portable and can be quickly deployed. Transport the fully collapsed stand in the included storage pouch. The width of this laptop computer stand is adjustable, ranging from 2-7.17in (5.1-18.2cm), ensuring multi-device compatibility. Once the stand is folded, the dimensions are 9.4 x 2 x 0.9in (24.1 x 5.1 x 2.4cm).
                Sturdy Laptop StandThe elegant laptop riser features aluminum construction to ensure durability and sturdiness and a silver anodized finish complements the design. The support area facilitate passive cooling by reducing airflow restriction around the base of the mounted device. Non-skid rubber feet protect the work surface from scratches and scuffs, including glass top desks. This product is backed for five years, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com Foldable Laptop Riser Stand, Portable Height Adjustable Ergonomic Laptop Stand, Ventilated Aluminum Frame Supports 22lb (10Kg), Tilt/Raised/Angled Laptop/Tablet Stand, Collapsible Design - notebook stand
- Product Type
- Notebook stand
- Placing / Mounting
- Desktop
- Package Content
- Carrying pouch, notebook riser
- Silver
- Product Material
- Aluminium
- 341 g
- Notebook Compatibility
- 15.6"
- Notebook Supported Sizes
- Up to 15.6" / up to 39.6 cm
- Multiple viewing angle, ergonomic holder width adjustable, adjustable angle (9 positions), portable, lightweight, tilt adjustment 15° to 84°, anti-slip pads
- 5-year warranty
- Product Type
- Notebook stand
- Desktop
- Product Material
- Aluminium
- Package Content
- Max Load Weight
- 10 kg
- Adjustable Width
- 5.1-18.2 cm
- 341 g
- Shipping Dimensions (WxDxH) / Weight
- 33 cm x 25 cm x 2.6 cm / 356 g
- 15.6"
- Silver
- Width adjustable, adjustable angle (9 positions), portable, lightweight, tilt adjustment 15° to 84°, anti-slip pads
- RoHS, REACH
- Limited warranty: - 5 years
|  | StarTech.com 15in Laptop Privacy Screen - Matte or Glossy - 16:9 Ratio | In Stock | £31.60 |
|  | StarTech.com 13in Laptop Privacy Screen - 16:10 Aspect Ratio | In Stock | £32.64 |
|  | StarTech.com Ergonomic Monitor Riser Stand | In Stock | £32.89 |
