StarTech.com Laptop Mini Docking Station
Quicklinx: 9YY6WS00 Mfr#: USB31GEVG
Add a Gigabit Ethernet RJ45 port and VGA output to your port-limited laptop, through USB 3.0. The USB31GEVG USB 3.0 Laptop Mini Docking Station lets you create a mobile workstation by adding VGA and Gigabit Ethernet connection ports to your Ultrabook or laptop, through a single USB 3.0 host - a travel-friendly solution giving you two connectivity ports that aren't always available on modern mobile computers.
The lightweight mini docking station is ideal for mobile environments, with a built-in cable and no external power adapter required. Plus, the mini dock tucks neatly into your travel bag, with a compact and portable design. While you're on the move, the USB31GEVG is the ultimate laptop accessory since it eliminates the hassle of carrying multiple adapters by consolidating two essential connection ports into one convenient device.
Adding an external monitor, projector, or TV to your laptop or desktop has never been easier! The multi-functional mini docking station leverages the high-bandwidth (5 Gbps) USB 3.0 interface to function as an external graphics card with VGA output and support for resolutions up to 2048x1152 (QWXGA). A versatile solution that lets you transform a workspace in to a mobile hot desk, the mini docking station also integrates an RJ45 port, giving you wired Gigabit bandwidth and faster network connections in environments where a typical WiFi connection is unreliable or not available.
To save you time, setup is seamless and hassle-free. The portable docking station will automatically download the latest driver when connected to a Windows system with an active network connection.
StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ VGA, GbE - USB 3.0 Gigabit Ethernet Adapter NIC w/ VGA - docking station - USB - VGA - GigE
Docking station
Docking Interface
USB
Video Interfaces
VGA
6.5 cm x 6.5 cm x 1.9 cm
47 g
Gigabit Ethernet
3-year warranty
Docking station
6.5 cm
6.5 cm
1.9 cm
47 g
Enclosure Colour
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 2.0, USB 3.0
1 x video - VGA - 15 pin HD D-Sub (HD-15) , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x SuperSpeed USB cable - integrated - 11.1 cm
USB powered
FCC, RoHS
Microsoft Windows XP (32-bit) SP3, Google Chrome OS 55 or later, Apple MacOS X 10.6 - 10.13.3, Apple macOS 11.0, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years
9YY6 StarTech.com DVI to VGA Cable Adapter - Black - F/M In Stock £7.33
9YY6 StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.59
9YY6 StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - Black In Stock £30.88
9YY6 StarTech.com StarStarTech.com Universal USB 3.0 Laptop Docking Station w/ Dual DVI Video In Stock £33.91
9YY6 StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable In Stock £38.89
9YY6 StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 In Stock £55.98
9YY6 StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £8.87
