Create a mobile workstation using your Ultrabook or laptop USB 3.0 port via this portable USB 3.0 mini dock. The USB3SMDOCKHV USB 3.0 Laptop Mini Docking Station lets you transform your Ultrabook or laptop into a mobile workstation, by adding HDMI or VGA video output, a USB 3.0 hub port, and a Gigabit Ethernet RJ45 port, all through a single USB 3.0 host connection - a travel-friendly solution that can help you overcome the connection port limitations of modern mobile computers.
Now, you can avoid the nuisance of carrying multiple adapters. By consolidating four essential connection ports into one convenient device, the USB3SMDOCKHV delivers the perfect laptop accessory. The mini docking station features a lightweight, compact design that fits nicely into your travel bag and also features an integrated host connection cable that tucks neatly into the docking stations casing.
A versatile solution for connecting an additional display to your laptop, the mini dock offers HDMI video output with audio, or VGA video output, providing two popular interfaces for connecting a television, projector, or monitor as a second display, with support for resolutions up to 2048x1152 (QWXGA). Leveraging the high-bandwidth (5 Gbps) USB 3.0 interface to deliver flexible video output, a USB 3.0 hub port, and Gigabit Ethernet, you can quickly set up a multi-functional workstation while on the run, without sacrificing one of your laptop USB ports.
Setup is seamless and hassle-free; the mini docking station will automatically download the latest driver when connected to a Windows system with an active network connection.
- StarTech.com USB 3.0 to HDMI or VGA Adapter Dock - USB 3.0 Mini Docking Station w/ USB, GbE Ports - Portable Universal Laptop Travel Hub (USB3SMDOCKHV) - docking station - USB - HDMI - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB
- Video Interfaces
- HDMI
- 5.5 cm x 12.5 cm x 1.7 cm
- 100 g
- Black
- Networking
- Gigabit Ethernet
- 3-year warranty
- Designed For
- P/N: ARMPIVOT, ARMPIVOTE, ARMPIVSTND, ARMSLIM, ARMUNONB
- Product Type
- Docking station
- 5.5 cm
- 12.5 cm
- 1.7 cm
- 100 g
- Enclosure Colour
- Black
- Data Link Protocol
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- 1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x display / video - output - 15 pin HD D-Sub (HD-15) , 1 x video - HDMI - 19 pin HDMI Type A
- FCC, RoHS
- OS Required
- Microsoft Windows XP (32-bit) SP3, Apple MacOS X 10.6 - 10.12, Apple macOS 11.0, Apple macOS 10.14 - 10.15, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- Limited warranty - 3 years
- 0 °C
- 40 °C
- Designed For
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.29 |
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £9.78 |
StarTech.com DVI to VGA Cable Adapter - Black - F/M | In Stock | £8.04 |
StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female | In Stock | £10.14 |
StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.94 |
StarTech.com Universal USB 3.0 Laptop Docking Station - Dual Video HDMI DVI VGA with Audio | In Stock | £71.06 |
StarTech.com StarStarTech.com Universal USB 3.0 Laptop Docking Station w/ Dual DVI Video | In Stock | £85.01 |
StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 | In Stock | £76.92 |
StarTech.com Universal USB 3.0 4K Laptop Docking Station w/ 4K DisplayPort | In Stock | £93.33 |
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £10.56 |
StarTech.com Triple-Video Laptop Dock | In Stock | £100.82 |
StarTech.com USB-C Multiport Adapter - DVI | In Stock | £51.00 |
StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 | In Stock | £69.35 |
StarTech.com USB C VGA Multiport Adapter | In Stock | £55.02 |
StarTech.com USB-C Multiport Adapter HDMI - SD Reader - 2xA 1xC - PD3.0 | In Stock | £60.36 |
StarTech.com USBC Multiport Adapter 4K 60Hz | In Stock | £82.20 |
StarTech.com USB C Multiport Adapter 2 HDMI | In Stock | £73.52 |
StarTech.com USBC Multiport Adapter 4K 60Hz | In Stock | £79.09 |
StarTech.com USB-C Multiport Adapter | In Stock | £75.53 |
StarTech.com USB C Multiport Adapter | In Stock | £108.26 |
StarTech.com USB-C Multiport Adapter, HDMI | In Stock | £35.73 |
StarTech.com USB-C Multiport Adapter, HDMI | In Stock | £30.42 |
StarTech.com USB-C Triple Monitor Docking Station | In Stock | £180.66 |
StarTech.com USB-C Multiport Adapter - HDMI/DP | In Stock | £74.24 |
StarTech.com USB-C Multiport Adapter - HDMI/VGA | In Stock | £33.39 |
StarTech.com USB-C Speakerphone Dock | In Stock | £96.54 |
