StarTech.com Laptop Cable Lock Anchor - Large
Quicklinx: FGG0WS00 Mfr#: LTANCHORL
Device Type: Other, Laptop
Type: Security
Device Screen Size: [N/A]
Colour: Silver
£11.18 ex VAT
£13.41 inc VAT
Create a versatile and secure anchor point in almost any location, to help guard your laptop, docking station or other device against theft. This laptop cable-lock anchor features a large ringed design that attaches easily to a solid surface, to provide a strong and secure anchor point for your cable lock (sold separately).
With its large ringed design, the cable lock anchor point provides ample room to thread thicker cable locks, or more than one cable through the 1.4" W x 0.7" H (35 x 19 mm) opening.
Protect your device, and your investment, by adding a laptop cable-lock anchor point to a desk, counter, cabinet, wall or other solid location. The screw-on cable lock anchor makes it easy to lock your laptop to your desk. It features a small footprint and is easy to attach using two screws and the adhesive pad (included). It gives you the convenience of choosing the location of the anchor point for your cable lock.
Made of durable zinc alloy, the ringed deskmount security anchor point can withstand a strong force from the cable lock in all directions. The robust construction of the computer security cable anchor helps to prevent the anchor point from being tampered with or cut. The security plate prevents access to the mounting screws.
  • Strong construction
    Made from high-quality steel, this lock anchor offers strength and durability for long-lasting use.
  • Complete installation kit
    The package comes with a cover plate, two wood screws, an abrasive pad, and an alcohol wipe for simple mounting.
StarTech.com Laptop Cable Lock Anchor - Large - Security Cable Anchor Point - lock anchor
Lock anchor
Package Content
Cover plate, 2 wood screws, abrasive pad, alcohol wipe
Silver
Product Material
Steel
6.7 cm x 4.7 cm x 3.1 cm
100 g
P/N: LTLOCKNBL
Lock anchor
Product Material
Steel
Package Content
6.7 cm
4.7 cm
3.1 cm
100 g
12 cm x 2 cm x 8.5 cm / 101 g
Silver
Limited warranty: - 2 years
P/N: LTLOCKNBL
FGG0 StarTech.com Laptop Cable Lock Anchor - Computer Security Cable Anchor In Stock £10.22
FGG0 StarTech.com Universal Laptop Lock, 3-in-1 In Stock £27.78
FGG0 StarTech.com Universal Laptop Lock, 3-in-1 In Stock £30.35
FGG0 StarTech.com 25-Pack Universal Laptop Lock In Stock £507.39
FGG0 StarTech.com 25-Pack Universal Laptop Lock In Stock £627.35
FGG0 StarTech.com 3-in-1 Universal Laptop Lock In Stock £27.51
FGG0 StarTech.com Universal Laptop Cable Lock In Stock £25.07
Device Type: Other
Device Type: Laptop
Type: Security
Colour: Silver
