The Nano-Slot Laptop Lock is an anti-theft cut-resistant cable lock designed to deter the theft of laptops and other ultra-slim notebooks. The laptop lock features a 6.5ft (2m) cut-resistant cable with a PVC coating, making it a durable and reliable solution for securing laptops. The lock body features zinc-alloy plating, which prevents corrosion and wear. The compact design of this lock is perfect for ultra-slim notebooks, 2-in-1 laptops, tablets, and many other devices that feature a Nano-Slot.
Full-Motion Lock Design
The diameter of the lock head is 0.4in (12.5mm), with an off-center lock tip that enables a ultrabook or slim laptops to lay flat when the lock is attached. Additionally, the lock head features both pivot and ball joints, allowing the lock to pivot 90° and rotate a full 360°. -
Keyed Anti-Theft Laptop Lock
Keyed anti-theft laptop lock has a push-to-lock system that allows for quick lock-unlock without the need to remember sequential numbers. It also features a spacer near the lock tip that protects the device from scuffing or denting the laptop's lock slot. The lock includes a set of two zinc alloy keys. -
Flexible Installation
The 6.5ft, 4.4mm cut-resistant steel wire can be routed through a grommet hole or attached to the leg of a table. It is the ideal security lock for tradeshows, POS, kiosks, office security, and product exhibits. Enhance the convenience and security of this product, using LTANCHOR or LTANCHORL (sold separately), to secure a device to a table or desk. The multitude of installation options ensures this lock will fit any application.
- StarTech.com Nano Laptop Cable Lock, 6ft (2m), Anti-Theft Keyed Lock, Security Cable Locks Nano Slot Computers, For HP EliteBook/Lenovo ThinkPad X1/2-1 Laptops, Cut-Resistant Steel Cable Lock For Laptop (NANOK-LAPTOP-LOCK) - security cable lock
- Product Type
- Security cable lock
- Package Content
- Hook-and-Loop fastening strap, 2 x keys
- Black, silver
- Product Material
- Plastic, steel
- 1.2 cm 2.3 cm
- Length
- 2 m
- 140 g
- Theft protection, Nano slot keyed lock
- 2-year warranty
- Product Type
- Product Material
- Plastic, steel
- Package Content
- 1.2 cm
- 2.3 cm
- Length
- 2 m
- 140 g
- Shipping Dimensions (WxDxH) / Weight
- 20.5 cm x 12.8 cm x 1 cm
- Black, silver
- Limited warranty: - 2 years
- -10 °C
- 60 °C
StarTech.com Laptop Cable Lock Anchor - Computer Security Cable Anchor | In Stock | £12.08 |
StarTech.com Laptop Cable Lock Anchor - Large | In Stock | £13.12 |
StarTech.com Laptop Cable Lock Expansion Loop - 6" / 2.5 cm Branch Cable | In Stock | £7.12 |
StarTech.com Laptop Nano Cable Lock, 5ft | In Stock | £17.15 |
