PORTABLE K-SLOT LAPTOP CABLE LOCK: 6ft (1.8m) Cut-resistant vinyl-coated steel coiled security locking cable (3.2mm thick); 20.3mm diameter lock head; Compatible with Kensington style slot; Tested up to 175lb of force.
3-DIGIT COMBINATION LOCK: Keyless 3-digit resettable combo code allows for up to 1000 combinations; Serialized self-coiling cable retracts to 10.5" in length; Ideal for stationary anchor points (ie. table legs).
SCRATCH PROTECTION: Laptop lock tip positioned for flush alignment with thin K-slot devices while laying flat on a desk surface to avoid damaging the lock slot; Rubber end prevents scuffs & scratches.
COMPATIBILITY: Works w/any K-Slot laptop (incl HP, Lenovo, Acer, Asus) and desktop computers/notebooks/monitors/docking stations among other devices that are typically equipped with a K-Slot.
STARTECH.COM ADVANTAGE:Incl. hook-and-loop strap keeps anti-theft cable lock organized, Accessorize with StarTech.com anchor points to secure equipment to any surface (LTANCHOR/LTANCHORL not included).
Reliable Construction
Crafted from vinyl and steel, this cable lock is designed to withstand wear and tear, providing a dependable security solution for valuable devices. -
Convenient Self-Coiling Design
The self-coiling feature ensures that the cable wraps neatly when not in use, eliminating mess and making it easy to transport. -
Customizable Locking Option
The resettable function allows users to set their own combination, adding a layer of personalization and security.
- StarTech.com 6ft (1.8m) Self-Coiling Laptop Cable Lock, Portable 3-Digit Combination Security Cable Lock for K-Slot Laptop/Computer/Desktop/Device, Coiled Anti-Theft Steel Cable Combo Lock - 6 ft Coiled Cable Lock (LTLOCK3DCOIL) - security cable lock
- Product Type
- Security cable lock
- Product Material
- Vinyl, steel
- 1.3 cm 2.03 cm
- Length
- 1.8 m
- 118 g
- Resettable function
- 2-year warranty
- Product Type
- Product Material
- Vinyl, steel
- 1.3 cm
- 2.03 cm
- Length
- 1.8 m
- 118 g
- Shipping Dimensions (WxDxH) / Weight
- 120 g
- Limited warranty: - 2 years
StarTech.com Laptop Cable Lock, Swivel Hinge - 4-Digit Combination Lock | In Stock | £15.86 |
StarTech.com Keyed Cable Lock - Push-to-Lock Button - 2 m / 6.5’ Cable | In Stock | £18.25 |
StarTech.com Laptop Cable Lock Expansion Loop - 6" / 2.5 cm Branch Cable | In Stock | £6.34 |
StarTech.com Laptop Cable Lock - 4-Digit Resettable Combination Lock - For Wedge Lock Slot | In Stock | £22.99 |
StarTech.com Universal Laptop Lock, 3-in-1 | In Stock | £28.21 |
StarTech.com Universal Laptop Lock, 3-in-1 | In Stock | £30.84 |
StarTech.com 25-Pack Universal Laptop Lock | In Stock | £507.39 |
StarTech.com 25-Pack Universal Laptop Lock | In Stock | £600.99 |
StarTech.com 25-Pack Universal Laptop Lock | In Stock | £627.35 |
StarTech.com 3-in-1 Universal Laptop Lock | In Stock | £27.51 |
StarTech.com Computer/Peripheral Lock Kit | In Stock | £32.44 |
StarTech.com Peripheral Cable Anchor Lock | In Stock | £2.91 |
StarTech.com Laptop Cable Lock - Self-Coiling Cable - 3-Digit Combination
