The StarTech.com 25-Pack Universal Laptop Lock offers an effective solution to secure a wide range of devices against theft. This keyed cable lock system is designed for compatibility with the Noble Wedge Slot, Kensington Nano Slot, and Kensington Standard Slot (K-Slot), making it suitable for securing docking stations, monitors, notebooks, printers, and projectors. Constructed from durable steel and plastic, the anti-theft, cut-resistant cable ensures your devices remain safe in any setting. Each package includes 25 laptop security locks, 50 keys, 75 lock spacers, and 25 hook-and-loop straps, providing a comprehensive security system for multiple devices. The master keyed locking mechanism allows for easy access by authorized personnel, simplifying device management while maintaining security. TAA compliance further assures the quality and reliability of this security solution, making it an ideal choice for protecting valuable equipment.
Versatile compatibility
Designed to fit a wide range of devices, this security cable lock is compatible with Kensington Nano Slot, Kensington Standard Slot (K-Slot), and Noble Wedge Slot, ensuring broad application across various equipment including docking stations, monitors, notebooks, printers, and projectors. -
Robust construction
Crafted from high-quality steel and plastic, the 25-Pack Universal Laptop Lock offers durable protection to secure your devices. The cut-resistant cable is designed to withstand attempts at tampering, providing peace of mind in any environment. -
Comprehensive security solution
This package includes 25 laptop security locks, 50 keys, 75 lock spacers, and 25 hook-and-loop straps, offering a complete security system for multiple devices. Master keyed locking mechanism allows for convenient access by authorized personnel while maintaining the integrity of your device's security.
- StarTech.com 25-Pack Universal Laptop Lock 6.6ft (2m), Master Keyed Locking Cable, Computer Security, Compatible w/Noble Wedge/Nano/K-Slot, Anti-Theft Cut-Resistant Cable - security cable lock
- Product Type
- Security cable lock
- Packaged Quantity
- 25 (specifications are for single item)
- Package Content
- 25 Laptop Security Locks, 50 keys, 75 lock spacers, 25 Hook-and-Loop Straps
- Black & silver
- Product Material
- Plastic, steel
- 1.4 cm 3.2 cm
- Length
- 2 m
- 125 g
- Kensington Nano Slot, Kensington Standard Slot (K-Slot), Noble Wedge Slot, anti-theft protection
- 2-year warranty
- Packaged Quantity
- Product Type
- Product Material
- Plastic, steel
- Package Content
- 1.4 cm
- 3.2 cm
- Length
- 2 m
- 125 g
- Shipping Dimensions (WxDxH) / Weight
- 33.3 cm x 25.8 cm x 12.7 cm / 3.9 kg
- Black & silver
Security Cable Lock
- Intended For
- Docking station, monitor, notebook, printer, projector
- Lock Type
- Nano, noble wedge, T-Bar
- Lock Method
- Key
- TAA Compliant
- Limited warranty: - 2 years
- -20 °C
- 40 °C
StarTech.com Laptop Cable Lock Anchor - Computer Security Cable Anchor | In Stock | £10.22 |
StarTech.com Laptop Cable Lock Anchor - Large | In Stock | £11.18 |
