StarTech.com Laptop Cable Lock - Self-Coiling Cable - 3-Digit Combination
Quicklinx: F3BBWS00 Mfr#: LTLOCK3DCOIL
Device Type: Laptop
Type: Security
Device Screen Size: [N/A]
Colour: Black/Silver
Hurry, only 2 left in stock!
£15.75 ex VAT
£18.90 inc VAT
PORTABLE K-SLOT LAPTOP CABLE LOCK: 6ft (1.8m) Cut-resistant vinyl-coated steel coiled security locking cable (3.2mm thick); 20.3mm diameter lock head; Compatible with Kensington style slot; Tested up to 175lb of force.
3-DIGIT COMBINATION LOCK: Keyless 3-digit resettable combo code allows for up to 1000 combinations; Serialized self-coiling cable retracts to 10.5" in length; Ideal for stationary anchor points (ie. table legs).
SCRATCH PROTECTION: Laptop lock tip positioned for flush alignment with thin K-slot devices while laying flat on a desk surface to avoid damaging the lock slot; Rubber end prevents scuffs & scratches.
COMPATIBILITY: Works w/any K-Slot laptop (incl HP, Lenovo, Acer, Asus) and desktop computers/notebooks/monitors/docking stations among other devices that are typically equipped with a K-Slot.
STARTECH.COM ADVANTAGE:Incl. hook-and-loop strap keeps anti-theft cable lock organized, Accessorize with StarTech.com anchor points to secure equipment to any surface (LTANCHOR/LTANCHORL not included).
  • Reliable Construction
    Crafted from vinyl and steel, this cable lock is designed to withstand wear and tear, providing a dependable security solution for valuable devices.
  • Convenient Self-Coiling Design
    The self-coiling feature ensures that the cable wraps neatly when not in use, eliminating mess and making it easy to transport.
  • Customizable Locking Option
    The resettable function allows users to set their own combination, adding a layer of personalization and security.
StarTech.com 6ft (1.8m) Self-Coiling Laptop Cable Lock, Portable 3-Digit Combination Security Cable Lock for K-Slot Laptop/Computer/Desktop/Device, Coiled Anti-Theft Steel Cable Combo Lock - 6 ft Coiled Cable Lock (LTLOCK3DCOIL) - security cable lock
Security cable lock
Product Material
Vinyl, steel
1.3 cm 2.03 cm
Length
1.8 m
118 g
Resettable function
Security cable lock
Product Material
Vinyl, steel
1.3 cm
2.03 cm
Length
1.8 m
118 g
120 g
Resettable function
Limited warranty: - 2 years
F3BB StarTech.com Laptop Cable Lock, Swivel Hinge - 4-Digit Combination Lock In Stock £15.51
F3BB StarTech.com Keyed Cable Lock - Push-to-Lock Button - 2 m / 6.5’ Cable In Stock £18.08
F3BB StarTech.com Laptop Cable Lock Expansion Loop - 6" / 2.5 cm Branch Cable In Stock £6.18
F3BB StarTech.com Laptop Cable Lock - 4-Digit Resettable Combination Lock - For Wedge Lock Slot In Stock £22.79
F3BB StarTech.com Universal Laptop Lock, 3-in-1 In Stock £27.09
F3BB StarTech.com Universal Laptop Lock, 3-in-1 In Stock £30.15
F3BB StarTech.com 25-Pack Universal Laptop Lock In Stock £577.21
F3BB StarTech.com 25-Pack Universal Laptop Lock In Stock £612.06
F3BB StarTech.com Computer/Peripheral Lock Kit In Stock £31.15
F3BB StarTech.com Peripheral Cable Anchor Lock In Stock £2.86
Device Type: Laptop
Type: Security
