StarTech.com Laptop Cable Lock - 4-Digit Resettable Combination Lock - For Wedge Lock Slot
Quicklinx: FVKXWS00 Mfr#: LTLOCKNBL
Device Type: Laptop
Type: Security
Device Screen Size: [N/A]
Colour: Silver/Black
10 In Stock
£22.99 ex VAT
£27.58 inc VAT
Portable Security Cable 6.5' (2 m) Steel Cable Swivel Hinge. Help guard your laptop against theft, while allowing full functionality. This laptop cable lock helps protect your laptop or other device equipped with a Noble  Wedgelock slot. The laptop anti-theft lock has a 4-digit resettable combination for enhanced security at the office or on the go.
Works with the Wedge-type Lock Slot
Ensure your laptop is protected. The computer anti-theft cable lock fits into laptops and devices equipped with a wedge lock slot. Attach your laptop to your desk or any fixed structure using the 2 m (6.5') locking cable. It's an easy way to help prevent theft in areas with high foot traffic including retail, commercial, educational and institutional environments.
Offers Greater Motion
While your notebook is secured with the anti-theft locking cable, you can still move it freely. The swivel hinge enables motion in two directions - the hinge rotates 360 degrees around the lock head, and pivots 90 degrees for easy locking and unlocking.
Resettable 4-Digit Combination Lock
Choose your own combination so you can remember it easily. Or, prevent others from knowing your passcode by changing it often. The 4-digit combination on the security cable lock is easy to change.
Versatile Use
Ideal for use at the office or when travelling, the portable combination lock features a strong vinyl-coated steel cable (4.4 mm diameter). To secure your device in different work spaces, the flexible steel cable bends easily to loop around a stationary post or object.
The TAA compliant LTLOCKNBL is backed by a StarTech.com 2-year warranty and free lifetime technical support.
  • Works with the wedge-type lock slot
  • Offers greater motion
  • Resettable 4-digit combination lock
  • Versatile use
    Ideal for use at the office or when traveling, the?portable combination lock?features a strong vinyl-coated steel cable (4.4 mm diameter). To secure your device in different work spaces, the flexible steel cable bends easily to loop around a stationary post or object.
StarTech.com 6.5’ (2m) Laptop Cable Lock, 4 Digit Combination Laptop/Desktop Security Cable Lock for Wedge Slot Computers/Laptops, Anti-Theft Vinyl-Coated Steel Combo Cable Lock, Portable - Wedge Slot Laptop Lock (LTLOCKNBL) - security cable lock - TAA Compliant
Security cable lock
Package Content
Hook-and-loop straps
Silver, black
Product Material
Vinyl-coated steel
5.4 cm x 2 m x 1.8 cm
Length
2 m
138 g
Combination lock, 4 digit code, wedge lock slot, swivel hinge, anti-theft protection, tamper-resistant
TAA Compliant
Security cable lock
Product Material
Vinyl-coated steel
Package Content
5.4 cm
2 m
1.8 cm
Length
2 m
138 g
3 cm x 14.2 cm x 17 cm / 150 g
Silver, black
TAA Compliant
Limited warranty: - 2 years
FVKX StarTech.com Laptop Cable Lock Anchor - Computer Security Cable Anchor In Stock £10.22
FVKX StarTech.com Laptop Cable Lock Anchor - Large In Stock £11.18
FVKX StarTech.com Laptop Cable Lock 6Ft In Stock £24.79
FVKX StarTech.com Universal Laptop Lock, 3-in-1 In Stock £27.78
FVKX StarTech.com Universal Laptop Lock, 3-in-1 In Stock £30.35
FVKX StarTech.com 25-Pack Universal Laptop Lock In Stock £507.39
FVKX StarTech.com 25-Pack Universal Laptop Lock In Stock £603.85
FVKX StarTech.com 25-Pack Universal Laptop Lock In Stock £627.35
FVKX StarTech.com 3-in-1 Universal Laptop Lock In Stock £27.51
FVKX StarTech.com Computer/Peripheral Lock Kit In Stock £31.93
FVKX StarTech.com Universal Laptop Cable Lock In Stock £25.07
Device Type: Laptop
Type: Security
