StarTech.com 25-Pack Universal Laptop Lock
Quicklinx: HSTRWS00 Mfr#: UNIVCS25-LAPTOP-LOCK
£507.39 ex VAT
£608.86 inc VAT
The 25-Pack Universal Laptop Lock is a versatile solution providing flexibility and convenience.
  • Adaptable security
    A unique on-the-fly lock tip mechanism allows to quickly adapt the lock tip to different security slots. Simply rotate the lock selection dial to change the shape of the lock tip to match the security slot, all without the need to carry different lock tips or use special tools. The cut-resistant steel security cable is 6.6 ft. (2 m) long and 0.17 in (4.4 mm) thick, providing reach and durability.
  • Serialized combination lock
    Each lock comes with its own pre-set combination code for streamlined security management for IT administrators working with multiple locks.
  • Widely compatible
    The versatile bulk-pack security lock is not limited to laptops or notebooks only. Use this lock to secure other devices such as docking stations, monitors, printers, SFF computers, projectors, oscilloscopes, or other office and lab equipment, expanding its utility. The lock is future-proof as it works with previous and newer computers from various brands. Different thickness spacers are provided to ensure a better fit for your device.
  • Full-motion lock design
    The diameter of the lock head is 0.4 in (14 mm) and features a ball joint design that allows for 360° rotation and 90° pivot of the lock head. This flexibility reduces coiling and minimizes strain on the notebook slot, enhancing durability and usability.
  • Flexible installation
    Simply loop the cable through a grommet hole or around a desk leg. Ideal for tradeshows and product exhibits.
StarTech.com 25-Pack Laptop Lock, Compatible w/Noble Wedge/Nano/K-Slot - security cable lock
Security cable lock
Packaged Quantity
25 (specifications are for single item)
Package Content
25 Laptop Security Locks, 25 Hook-and-Loop Straps, 75 Bumper Spacers, 25 Quick-Start Guide
Black, silver
Product Material
Plastic, steel
1.4 cm 4.6 cm
Length
2 m
146 g
Theft protection, Kensington Nano Slot, Noble Wedge Slot, Kensington Standard Slot (K-Slot)
Packaged Quantity
Security cable lock
Product Material
Plastic, steel
Package Content
1.4 cm
4.6 cm
Length
2 m
146 g
17.4 cm x 27.3 cm x 23.6 cm / 3.9 kg
Black, silver
Security Cable Lock
Intended For
Notebook, docking station
Lock Type
Wedge, nano, standard, noble wedge, noble
Lock Method
Combination
TAA Compliant
Limited warranty: - 2 years
HSTR StarTech.com Laptop Cable Lock Anchor - Computer Security Cable Anchor In Stock £10.22
HSTR StarTech.com Laptop Cable Lock Anchor - Large In Stock £11.18
HSTR StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop In Stock £7.52
HSTR StarTech.com 25-Pack Universal Laptop Lock In Stock £600.99
HSTR StarTech.com 25-Pack Universal Laptop Lock In Stock £627.35
HSTR StarTech.com 3-in-1 Universal Laptop Lock In Stock £27.51
HSTR StarTech.com Universal Laptop Cable Lock In Stock £25.07
Price Range Ex VAT: £500 - £750
