StarTech.com Juniper EX-SFP-1GE-SX SFP - MM
Quicklinx: CRG7WS00 Mfr#: EXSFP1GESXST
Type: Transceiver
12 In Stock
£32.96 ex VAT
£39.55 inc VAT
Add reliable and cost-effective Gigabit Ethernet connections over multimode fiber with this SFP module. This StarTech.com Gigabit fiber SFP is engineered to deliver reliable network connections. Built to exacting specifications and fully tested to ensure maximum performance, this high-quality fiber transceiver module can be installed into Juniper Networks switches and routers that support the Juniper EX-SFP-1GE-SX transceiver module, as well as other major brands of networking equipment.
This 1000Base-SX SFP transceiver module delivers Gigabit connectivity over multimode fiber cable, with a range of up to 550 m (1804 ft.). It provides a dependable and cost-effective way to add, replace or upgrade the ports on your networking equipment.
This multimode SFP transceiver is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
The MM Gigabit SFP is engineered to the highest quality standards and is 100% Juniper Networks compatible, equivalent to the Juniper EX-SFP-1GE-SX SFP transceiver. The StarTech.com SFP transceiver is configured and fully tested to ensure it works seamlessly with Juniper Networks or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and cost-effective solution that's compatible with a multitude of Gigabit networking devices.
Ideal for use in switches, routers, and other networking equipment, the SFP provides reliable performance, allowing you to expand your network to remote segments cost-effectively. The SFP supports multimode fiber cable with a maximum distance of 550 m or 1804 ft., and maximum data rates of up to 1.25Gbps. This GbE fiber SFP also supports Digital Diagnostics Monitoring (DDM / DOM).
StarTech.com Juniper EX-SFP-1GE-SX Compatible SFP Module, 1000BASE-SX, 1GbE Multimode Fiber MMF Optic Transceiver, 1GE Gigabit Ethernet SFP, LC Connector, 550m, 850nm, DDM, Mini GBIC Module - Lifetime Warranty (EXSFP1GESXST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1.25 Gbps
Optical Wave Length
850 nm
1GbE
Max Transfer Distance
550 m
1.37 cm x 5.66 cm x 1.25 cm
28 g
Plug-in module
Silver
Wired
Cabling Type
1000Base-SX
1GbE
Data Transfer Rate
1.25 Gbps
Optical Wave Length
850 nm
550 m
Full duplex mode, Digital Optical Monitoring (DOM) support, Digital Diagnostics Monitoring (DDM)
IEEE 802.3z
1 x Ethernet 1000Base-SX - LC multi-mode female
UL, FCC, RoHS, MSA
1.37 cm
5.66 cm
1.25 cm
28 g
Limited warranty - lifetime
70 °C
5 - 95%
CRG7 StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £15.24
CRG7 StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £24.58
CRG7 StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £15.80
CRG7 StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £20.04
CRG7 StarTech.com 3m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £17.38
CRG7 StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £146.68
CRG7 StarTech.com Fiber Media Converter - Open In Stock £44.55
CRG7 StarTech.com Juniper EX-SFP-1GE-LX SFP In Stock £34.99
CRG7 StarTech.com Juniper EX-SFP-1GE-SX SFP - MM In Stock £32.96
CRG7 StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £338.20
Type: Transceiver
