StarTech.com In-Wall 300 Mbps 2T2R Wireless-N Access Point - 2.4GHz 802.11b/g/n PoE-Powered WiFi AP
Quicklinx: 9TV0WS00 Mfr#: AP300WN22WUE
  • IEEE 802.11n
Install a PoE-Powered, in-wall 802.11b/g/n access point with 2 RJ45 LAN / phone ports. This in-wall access point provides network and internet availability for both wired and wireless users. The sleek in-wall design with PoE enables you to use your existing CAT5 infrastructure to easily replace your standard RJ45 jacks, adding the benefits of dual LAN ports and Wireless-N connectivity.
This access point can be discretely integrated into any room where internet or network access is required. The wireless AP installs into any standard 1-gang receptacle box and features an elegant design for a seamless integration into any modern space. The sleek design ensures a tidy professional installation that is perfect for hotel rooms, hospitals, offices and schools.
The wireless access point is powered using Power over Ethernet to conveniently connect both data and power using an 802.3af PoE switch or injector, avoiding the hassle of in-wall power or external power adapters. The access point offers two front RJ45 Ethernet ports, with the first operating over the PoE connection and the second offering a transparent pass-through port that can be used for either a phone connection or a secondary LAN drop. The easy-to-incorporate nature of this AP is ideal for system integrators when planning the construction phase of schools, offices or residential buildings.
For fast performance the wireless AP is compatible with 802.11b/g/n standard supporting wireless data rates up to 300 Mbps on the 2.4GHz frequency. For a secure connection the access point supports WEP, WPA, and WPA2 authentication. The device also incorporates an easy-to-use web-based utility to provide several customization options such as multiple SSIDs, remote firmware upgrades and event reporting.
StarTech.com In-Wall 300 Mbps 2T2R Wireless-N Access Point - radio access point - Wi-Fi
Radio access point
In-wall mountable
MediaTek MT7620n
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Power Over Ethernet (PoE) Supported
PoE
3.9 cm x 7.2 cm x 5.5 cm
84 g
Radio access point
3.9 cm
7.2 cm
5.5 cm
84 g
Enclosure Colour
White
Processor / Memory / Storage
Processors Installed
MediaTek MT7620n
In-wall mountable
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
Frequency Band
2.4 GHz
Status Indicators
Power, system, wireless
Full duplex capability, power over Ethernet (PoE), 2T2R MIMO technology, Direct Sequence Spread Spectrum (DSSS)
Encryption Algorithm
AES, TKIP, WPA, WEP
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.11n
Aerial
Antenna
Internal
FCC, RoHS
PoE
50 °C
20 - 90% (non-condensing)
9TV0 StarTech.com 3m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £8.22
9TV0 StarTech.com 5m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £7.38
