StarTech.com HP JG325A Compatible QSFP+ MM Module - 40GBase-SR4
Quicklinx: FHJNWS00 Mfr#: JG325A-ST
The JG325A-ST is a HP JG325B compatible fiber transceiver module that has been designed, programmed and tested to work with HP brand switches and routers. It delivers dependable 40 GbE connectivity over fiber cable, for 40GBase-SR4 compliant networks, with a maximum distance of up to 150 m (492 ft).
This QSFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of QSFP+ modules and direct-attach QSFP+ cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com HPE JG325A Compatible QSFP+ Module, 40GBASE-SR4, 40GbE Multimode Fiber Optic Transceiver, 40GE Gigabit Ethernet QSFP+, MPO 150m, 850nm, DDM, HPE 5900AF, 11908, FlexFabric - Lifetime Warranty (JG325A-ST) - QSFP+ transceiver module - 40GbE
QSFP+ transceiver module - MPO multi-mode
Plug-in module
Cabling Type
40GBASE-SR4
Data Transfer Rate
40 Gbps
Optical Wave Length
850 nm
40GbE
Max Transfer Distance
150 m
HP JG325A
12.2 cm x 1.86 cm x 0.85 cm
37.5 g
HPE 5900AF-48G-4XG-2QSFP+ Switch, 5900AF-48XG-4QSFP+ Switch, 5900AF-48XGT-4QSFP+ Switch; FlexFabric 1.92 Tbps Type D Fabric Module, 11908-V Switch Chassis
Plug-in module
Wired
Cabling Type
40GBASE-SR4
40GbE
Data Transfer Rate
40 Gbps
Optical Wave Length
850 nm
150 m
Digital Diagnostics Monitoring (DDM)
1 x Ethernet 40GBASE-SR4 - MPO multi-mode female
MTBF
244,610,583 hours
MSA
HP JG325A
12.2 cm
1.86 cm
0.85 cm
37.5 g
Shipping Width
12 cm
Shipping Depth
20.5 cm
Shipping Height
3.5 cm
Shipping Weight
60 g
Limited warranty - lifetime
HPE 5900AF-48G-4XG-2QSFP+ Switch, 5900AF-48XG-4QSFP+ Switch, 5900AF-48XGT-4QSFP+ Switch , HPE FlexFabric 1.92 Tbps Type D Fabric Module, 11908-V Switch Chassis
