StarTech.com Extreme Networks 10051 Comp SFP MM Module - 1000Base-SX
Quicklinx: FHGSWS00 Mfr#: 10051-ST
Type: Modules
£22.35 ex VAT
£26.82 inc VAT
The 10051-ST is an Extreme Networks 10051 compatible fiber transceiver module that has been designed, programmed and tested to work with Extreme Networks brand switches and routers. It delivers dependable 1 GbE connectivity over fiber cable, for 1000Base-SX compliant networks, with a maximum distance of up to 550 m (1804 ft).
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Extreme Networks 10051 Compatible SFP Module, 1000BASE-SX, 1GbE Multimode Fiber MMF Optic Transceiver, 1GE Gigabit Ethernet SFP, LC 550m, 850nm, DDM, Mini GBIC - Lifetime Warranty (10051-ST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
1GbE
Max Transfer Distance
550 m
5.56 cm x 1.37 cm x 1.25 cm
16 g
Summit 24e3; Alpine 3802; Extreme Networks GM-16T3, GM-16X3
Plug-in module
Wired
Cabling Type
1000Base-SX
1GbE
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
550 m
Full duplex capability, Digital Diagnostics Monitoring (DDM)
1 x Ethernet 1000Base-SX - LC multi-mode female x 2
MTBF
629,953,711 hours
FCC, MSA
5.56 cm
1.37 cm
1.25 cm
16 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
Summit 24e3 , Alpine 3802 , Extreme Networks GM-16T3, GM-16X3
Type: Modules
