StarTech.com HP JD094A Compatible SFP+ SM Module - 10GBase-LR
Quicklinx: FHJMWS00 Mfr#: JD094A-ST
The JD094A-ST is an HP JD094A compatible fiber transceiver module that has been designed, programmed and tested to work with HP brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-LR compliant networks, with a maximum distance of up to 10 km (6.2 mi).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP+ modules and direct-attach SFP+ cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com HPE JD094A Compatible SFP+ Module, 10GBASE-LR, 10GbE Single Mode (SMF) Fiber Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC Connector, 10km, 1310nm, DDM, HPE 5900, 12500, 5500 - Lifetime Warranty (JD094A-ST) - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC single-mode
Plug-in module
Cabling Type
10GBase-LR
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10GbE
Max Transfer Distance
10 km
HP JD094A
5.84 cm x 1.39 cm x 1.37 cm
21 g
HPE 7502, 7503-S Switch with 1 Fabric Slot, 7506, 7506-V, 9505, 9508-V, 9512; FlexNetwork 7503, 7510 Switch with 2x2.4Tbps Fabric and Main Processing Unit
Plug-in module
Wired
Cabling Type
10GBase-LR
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 km
Full duplex mode, Digital Diagnostics Monitoring (DDM)
1 x Ethernet 10GBase-LR - LC single-mode female x 2
MTBF
1,386,624,697 hours
MSA
HP JD094A
1.3 Watt
5.84 cm
1.39 cm
1.37 cm
21 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
HPE 7502, 7503-S Switch with 1 Fabric Slot, 7506, 7506-V, 9505, 9508-V, 9512 , HPE FlexNetwork 7503, 7510 Switch with 2x2.4Tbps Fabric and Main Processing Unit
