Add reliable and cost-effective Gigabit Ethernet connections with this SFP module. This HP compatible Gigabit Copper SFP is engineered by StarTech.com to deliver what you need most in your network connections: reliable performance. Built to exacting specifications and fully tested to ensure maximum performance, this high-quality SFP transceiver module can be installed into HP networking devices that support the HP JD089B SFP transceiver module, as well as other major brands of networking equipment.
The SFP transceiver provides 10Base-T / 100Base-TX / 1000Base-T throughput over a distance of up to 100 m (328 ft.) using a copper RJ-45 connection. It provides a dependable and cost-effective way to add, replace or upgrade a copper Ethernet port on your networking equipment.
This Gigabit RJ45 copper SFP is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
This Gigabit Copper SFP is engineered to the highest quality standards and is 100% HP compatible, equivalent to the HP JD089B transceiver. The StarTech.com transceiver is configured and fully tested to ensure it works seamlessly with HP or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this SFP is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and convenient solution that's compatible with a multitude of multi and single-port Gigabit Ethernet networking devices.
Ideal for use in HP switches, routers and other networking equipment, the SFP provides reliable performance, enabling you to expand your network to remote segments cost-effectively. The SFP supports auto-negotiation, maximum distance of up to 100 m (328 ft.), and maximum data rates of up to 1000Mbps.
Reliable connectivity
This SFP module is designed for wired connectivity using an RJ-45 connector, allowing for integration into existing networking equipment. -
Efficient data transfer
With a data transfer rate of 1 Gbps, the module ensures quick and smooth data communication across networks. -
Versatile environmental operation
Capable of functioning at temperatures from 0°C to 70°C, this module maintains reliable performance in diverse conditions. -
Broad standard compliance
The module adheres to essential standards, including UL, FCC, RoHS, and MSA, for safe and effective operation. -
Flexible application range
Supports a maximum transfer distance of 100 m, making it suitable for a variety of networking applications.
- Startech HPE JD089B Compatible SFP Module, 1000BASE-T, SFP to RJ45 Cat6/Cat5e, 1GE Gigabit Ethernet SFP, RJ-45 (Copper) 100m, HPE 5820AF, 12500, 5500, 1Gbps Mini GBIC Transceiver SFP - Lifetime Warranty (JD089BST) - SFP (mini-GBIC) transceiver module - 1GbE
- SFP (mini-GBIC) transceiver module - RJ-45
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-T
- Data Transfer Rate
- 1 Gbps
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 100 m
- OEM Manufacturer Equivalent Part Number
- HP JD089B
- 1.37 cm x 6.8 cm x 1.38 cm
- 35 g
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-T
- 1GbE
- 1 Gbps
- 100 m
- Auto-negotiation, full duplex mode
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- 1 x Ethernet 1000Base-T - RJ-45 female
- UL, FCC, RoHS, MSA
- HP JD089B
- 1.37 cm
- 6.8 cm
- 1.38 cm
- 35 g
- Limited warranty - lifetime
- 0 °C
- 70 °C
- 5 - 95%
StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £31.89 |
StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC | In Stock | £142.63 |
StarTech.com Fiber Media Converter - Open | In Stock | £43.33 |
StarTech.com SFP - HP J4858C Comp. 10 Pack | In Stock | £227.46 |
StarTech.com SFP+ - HP JD092B Compatible | In Stock | £126.25 |
StarTech.com SFP - HP J4859C Compatible | In Stock | £40.56 |
StarTech.com Gb Copper SFP HP 453154-B21 Compatible | In Stock | £30.29 |
StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports | In Stock | £335.67 |
StarTech.com HP JD089B Compatible SFP
