This USB 3.1 (10Gbps) hard drive enclosure is a spare SATA drive enclosure for use with the StarTech.com S251BU31REM Hot-Swap Hard Drive Bay for 2.5" SATA SSD/HDD.
Add swappable storage capability
This SATA to USB enclosure can be used as an extra hard drive enclosure for the hot-swap bay in order to provide multiple enclosures that can be swapped in and out of a main computer system. It's perfect for adding drives for backup rotations, and data recovery strategies. -
Take your data with you
If you need access to your data outside of the office, you can use the enclosure as a standard USB 3.1 (10 Gbps) enclosure - a powerful external storage solution when you need access to your files while you're on the road. The enclosure includes a Micro-USB to USB-A and a Micro-USB to USB-C cable, so you can plug the enclosure into your laptop and access your data anywhere you go.
- StarTech.com Hot Swap Hard Drive Bay for 2.5" SATA SSD / HDD - Portable - USB 3.1 (10Gbps) Removable Hard Drive Enclosure (S251BU31REM) - storage enclosure - SATA 6Gb/s - SATA 6Gb/s, USB-C
- Storage enclosure - external
- Bus Type
- SATA 6Gb/s, USB-C
- Expansion Bays
- 1 x internal - 2.5"
- Hard Drive Form Factor Compatibility
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive, solid state drive
- Max Storage Devices Qty
- 1
- Product Material
- Aluminium
- Power Source
- USB bus
- 2-year warranty
- Designed For
- P/N: S251BU31REMD
- 2.5"
- Hard Drive Maximum Height
- 9.5 mm
- Host Bus
- SATA 6Gb/s, USB-C
- Product Material
- Aluminium
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- 1
- Processor
- ASMedia ASM1351
- Bays
- 1 x SATA 6Gb/s (internal)
- Connections
- 1 x USB 3.1 (Gen 2) - 24 pin USB-C , 1 x SATA 6Gb/s - 22 pin Serial ATA
- Included Accessories
- Mounting hardware
- Cables Included
- 1 x USB-C to micro-USB cable - external , 1 x micro-USB to USB cable - external
- LED indicator, UASP transfer protocol, tested with up to 2TB 7200 RPM hard drives
- MTBF
- 100,000 hours
- FCC, RoHS
- Power Source
- USB bus
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 90%
- Designed For
- P/N: S251BU31REMD
StarTech.com 18" Serial ATA Cable w/R Angle | In Stock | £5.00 |
StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter | In Stock | £5.16 |
StarTech.com LP4 to SATA Power Cable Adapter with Floppy Power | In Stock | £3.56 |
StarTech.com 5.25in Trayless Hot Swap Mobile Rack for 3.5in Hard Drive | In Stock | £16.79 |
StarTech.com 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane | In Stock | £40.71 |
StarTech.com 36in SATA to Right Angle SATA Serial ATA Cable | In Stock | £3.75 |
StarTech.com 4x SATA Power Splitter Adapter Cable | In Stock | £5.86 |
StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £10.77 |
StarTech.com 1m USB 3.1 C to Micro-B Cable | In Stock | £11.39 |
StarTech.com USB 3.1 Gen 2 Enclosure | In Stock | £43.79 |
StarTech.com 0.5m USB 3.1 C - Micro B Cable | In Stock | £10.29 |
StarTech.com Hot Swap Bay 2.5" SATA SSD HDD | In Stock | £45.40 |
