This plastic, floppy-drive adapter bracket lets you install a 3.5in floppy drive into a 5.25in bay. A simple solution that lets you position a 3.5in floppy drive in a computer case as needed (without being confined to the 3.5in floppy bay determined by the case layout), the floppy drive adapter bracket features an attractive open-faced black bezel that provides a snug, secured fit for installed drives.
- StarTech.com 3.5" to 5.25" Front Bay Adapter - Mount 3.5" HDD in 5.25" Bay - Hard Drive Mounting Bracket w/ Mounting Screws (BRACKETFDBK) - storage bay adapter
- Storage bay adapter
- Black
- Expansion Bays
- 1 x front accessible - 3.5" x 1/3H
- Compatible Bay
- 1 5.25" x 1/2H
- Product Material
- Metal
- 14.6 cm x 13.3 cm x 2.9 cm
- 2-year warranty
- Designed For
- P/N: 25SATSAS35HD, 35BAYCF2IDE, 35BAYUSB3S4, 35FCREADBK3, 35FCREADBU3, 35SAT225S3R, HSB220SAT25B, HSB225S3R, S251BU31REM, SAT2IDEADP, SATBP125VP, ST521PMINT
- Product Material
- Metal
- Black
Storage Controller
- Processor
- No CPU
- Bays
- Compatible Bay
- 1 x external 5.25" x 1/2H
- Limited warranty - 2 years
- 14.6 cm
- 13.3 cm
- 2.9 cm
- Designed For
StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter | In Stock | £4.92 |
StarTech.com 3.5in Drive Bay IDE to Single CF SSD Adapter Card Reader | In Stock | £16.74 |
StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks | In Stock | £17.52 |
StarTech.com 3.5in Front Bay 22-in-1 USB 2.0 Internal Multi Media Memory Card Reader - Black | In Stock | £12.15 |
StarTech.com USB 3.0 Multi-Card Reader | In Stock | £28.17 |
StarTech.com Hot Swap Bay 2.5" SATA SSD HDD | In Stock | £41.44 |
StarTech.com 2.5" SATA Drive Hot Swap Bay | In Stock | £22.64 |
