StarTech.com High Resolution VGA to Composite (RCA) or S-Video Converter - PC to TV
Quicklinx: 67CJWS00 Mfr#: VGA2VID
Type: VGA
£87.60 ex VAT
£105.12 inc VAT
Connect a PC with VGA output to a composite or S-video TV. This high resolution VGA to composite or S-video converter is a simple hardware solution that allows you to convert a VGA/PC video signal into a composite or S-video signal for use with a CRT or flat panel display.
The ideal solution for synchronizing monitors with television displays etc., the VGA to composite/S-video converter offers selectable NTSC or PAL format operating modes to ensure compatibility with virtually any configuration.
StarTech.com High Resolution VGA to Composite (RCA) or S-Video Converter - PC to TV Video Adapter - 1600x1200 RGB to TV (VGA2VID) - video converter - black
Video converter
Graphics Engine
- up to
Max Resolution
1152 x 864
1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x S-video output - 4 pin mini-DIN , 1 x composite video output - RCA
Enclosure Colour
1-year warranty
Video converter
Max Resolution
1152 x 864
1 x VGA input - 15 pin HD D-Sub (HD-15) - female , 1 x S-video output - 4 pin mini-DIN - female , 1 x composite video output - RCA - female
Video Input
Digital Video Capture Resolution
640 x 480, 1600 x 1200
Video Output
Analogue Video Format
NTSC, PAL
1 x composite video cable - 91 cm
FCC, RoHS
Enclosure Colour
Limited warranty - 1 year
70 °C
67CJ StarTech.com 3 ft USB to Type M Barrel 5V DC Power Cable In Stock £5.04
67CJ StarTech.com Composite and S-Video to HDMI Converter with Audio In Stock £116.88
67CJ StarTech.com VGA to HDMI Adapter with USB Audio & Power- Portable VGA to HDMI Converter 1080p In Stock £37.67
67CJ StarTech.com HDMI to RCA Converter Box In Stock £70.91
Type: VGA
