StarTech.com Composite and S-Video to VGA Video Scan Converter
Quicklinx: 7TXJWS00 Mfr#: VID2VGATV2
Hurry, only 3 left in stock!
£125.24 ex VAT
£150.28 inc VAT
Convert and Scale a Composite or S-Video Signal to Work with a VGA Display. The VID2VGATV2 Composite and S-Video to VGA Video Scan Converter (with Scaler) provides a simple way to convert Composite or S-Video signals to VGA (or Component RCA) output, for use with computer monitors, projectors or HDTV sets. Equipped with an On-Screen Display (OSD) menu and dip switches for simple configuration and selection of your video output settings, this compact video scaler installs quickly and easily for a true plug-and-play experience. An integrated scaler circuit dynamically converts the S-Video or Composite video input signal, giving you multiple output resolutions to choose from, to ensure compatibility with your display or projector. Plus, the Component/S-Video-VGA Converter includes a VGA to Component (RCA) breakout cable, which enables you to connect to TV sets that are not equipped with a VGA port.
  • Versatile connectivity options
    This converter features connectors for 4-pin mini-DIN, 15-pin HD D-Sub, and RCA, allowing connection to a variety of devices for greater flexibility in setups.
  • High-resolution support
    It supports resolutions up to UXGA and HDTV, enabling clear and detailed video output for enhanced viewing experiences.
  • Environmentally friendly design
    Operates efficiently within a temperature range of 0 °C to 40 °C and humidity levels of 0 to 60%, making it suitable for varied environments.
StarTech.com Composite and S-Video to VGA Video Scan Converter - composite to VGA - scan Converter - s-Video to VGA (VID2VGATV2) - video converter - black
Video converter
Graphics Engine
- up to
1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x component video output - RCA x 3 (with adapter)
6.4 cm x 11.2 cm x 2.6 cm
Enclosure Colour
P/N: SVA5M3NEUA
Video converter
1 x S-video input - 4 pin mini-DIN - female , 1 x composite video input - RCA - female , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female , 1 x component video output - RCA x 3 (with adapter) - male
Video Output
Supported Display Graphics
XGA (1024x768), SXGA (1280x1024), UXGA (1600x1200), HDTV (1920x1080)
Analogue Video Format
NTSC, PAL
1 x VGA / component video adapter - 91.44 cm
Plug and Play
6.4 cm
11.2 cm
2.6 cm
90 g
Enclosure Colour
0 - 60%
P/N: SVA5M3NEUA
7TXJ StarTech.com High Resolution VGA to Composite (RCA) or S-Video Converter - PC to TV In Stock £85.18
7TXJ StarTech.com DC Power Adapter - 5V, 3A In Stock £12.01
