Connect a PC with VGA output to a composite or S-video TV. This high resolution VGA to composite or S-video converter is a simple hardware solution that allows you to convert a VGA/PC video signal into a composite or S-video signal for use with a CRT or flat panel display.
The ideal solution for synchronizing monitors with television displays etc., the VGA to composite/S-video converter offers selectable NTSC or PAL format operating modes to ensure compatibility with virtually any configuration.
- StarTech.com High Resolution VGA to Composite (RCA) or S-Video Converter - PC to TV Video Adapter - 1600x1200 RGB to TV (VGA2VID) - video converter - black
- Video converter
- Graphics Engine
- - up to
- Max Resolution
- 1152 x 864
- 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x S-video output - 4 pin mini-DIN , 1 x composite video output - RCA
- Enclosure Colour
- Black
- 1-year warranty
- Video converter
- Max Resolution
- 1152 x 864
- 1 x VGA input - 15 pin HD D-Sub (HD-15) - female , 1 x S-video output - 4 pin mini-DIN - female , 1 x composite video output - RCA - female
Video Input
- Digital Video Capture Resolution
- 640 x 480, 1600 x 1200
Video Output
- Analogue Video Format
- NTSC, PAL
- Cables Included
- 1 x composite video cable - 91 cm
- FCC, RoHS
- Enclosure Colour
- Black
- Limited warranty - 1 year
- 0 °C
- 70 °C
StarTech.com 3 ft USB to Type M Barrel 5V DC Power Cable | In Stock | £5.04 |
StarTech.com Composite and S-Video to VGA Video Scan Converter | In Stock | £122.16 |
StarTech.com VGA to HDMI Adapter with USB Audio & Power- Portable VGA to HDMI Converter 1080p | In Stock | £36.47 |
StarTech.com DisplayPort VGA HDMI Converter Switch | In Stock | £150.51 |
StarTech.com HDMI to RCA Converter Box | In Stock | £62.76 |
StarTech.com S-Video or Composite to HDMI Converter with Audio - 720p - video converter - black | In Stock | £66.78 |
