Universal Server Rack Casters - Bolt Pattern: 45mm x 75 mm - Hardware Included
This set of four M6 2-inch casters, while designed for StarTech.com racks, can be added to the bottom of any server equipment rack, network rack, A/V rack, etc. with a 45mm x 75mm bolt pattern. Ideal for replacing damaged casters or upgrading a standing rack to a rolling rack for additional mobility. RKCASTER2 is backed by a lifetime warranty and free technical support.
StarTech.com Rack Compatibility
Replacement Casters For:
Optional Casters For*:
[%product id="4POSTRACK12U" text="4POSTRACK12U"%]
[%product id="RK1224WALHM" text="RK1224WALHM"%]
[%product id="4POSTRACK25U" text="4POSTRACK25U"%]
[%product id="RK1232WALHM" text="RK1232WALHM"%]
[%product id="RK1233BKM" text="RK1233BKM"%]
[%product id="RK1520WALHM" text="RK1520WALHM"%]
[%product id="RK1833BKM" text="RK1833BKM"%]
[%product id="RK2620WALHM" text="RK2620WALHM"%]
[%product id="RK2433BKM" text="RK2433BKM"%]
[%product id="RK616WALM" text="RK616WALM"%]
[%product id="RK2537BKM" text="RK2537BKM"%]
[%product id="RK9WALM" text="RK9WALM"%]
[%product id="RK4242BK24" text="RK4242BK24"%]
[%product id="RK4242BK30" text="RK4242BK30"%]
*Optional casters are sold separately.
2-inch caster wheels
Four-pack of universal swivel casters can be used as replacements on portable/mobile 4-post racks such as RK1833BKM, RK2433BKM, RK4242BK24 or to convert a floor rack to a rolling rack when casters are not included. -
Heavy-duty load capacity
Tested to 1.6 times their rated load capacity to ensure performance, these heavy-duty casters/wheels, can individually support up to a stationary load of 550 lbs. (250 kg) or a rolling load of 165 lbs. (75 kg). -
This caster kit can be used on any rack with a 45mm x 75mm bolt pattern to replace damaged casters and upgrade a floor rack to a rolling rack for additional mobility.
- StarTech.com Heavy Duty Casters for Server Racks/Cabinets, Set of 4 Universal M6 2-inch Swivel Caster Kit, 45x75mm Pattern, Replacement Caster Wheels for 4 Post Racks, Steel/Plastic - 4-Pack Rolling Caster Kit (RKCASTER2) - rack casters kit
- Product Type
- Rack casters kit
- Package Content
- 4 casters, 18 M6 screws, 18 M6 flat washers, 18 M6 cage nuts
- Black, silver
- Product Material
- Cold-rolled steel, plastic
- 6.5 cm x 9.2 cm x 7.25 cm
- 2.4 kg
- Limited lifetime warranty
- Product Type
- Rack casters kit
- Product Material
- Package Content
- 6.5 cm
- 9.2 cm
- 7.25 cm
- Diameter
- 50 mm
- 2.4 kg
- Shipping Dimensions (WxDxH) / Weight
- 22.5 cm x 12.5 cm x 9 cm / 2.6 kg
- Black, silver
- Weight Limit
- 250 kg
- RoHS
- Limited warranty: - lifetime
StarTech.com 42U Adjustable Depth Open Frame 4 Post Server Rack Cabinet - Casters Levelers and Hooks | In Stock | £203.32 |
StarTech.com 25U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks | In Stock | £192.50 |
StarTech.com 12U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks | In Stock | £165.22 |
StarTech.com 12U Server Rack Cabinet | In Stock | £404.63 |
StarTech.com 18U Server Rack Cabinet | In Stock | £421.07 |
StarTech.com 24U Server Rack Cabinet | In Stock | £595.67 |
StarTech.com 6U Wall-Mount Rack Cabinet | In Stock | £148.99 |
StarTech.com 26U Server Rack Enclosure | In Stock | £463.46 |
StarTech.com 9U Wall-Mount Rack Cabinet | In Stock | £174.53 |
StarTech.com 12U Server Rack Enclosure | In Stock | £330.35 |
StarTech.com 15U Server Rack Enclosure | In Stock | £313.10 |
StarTech.com 25U Server Rack Cabinet | In Stock | £875.30 |
StarTech.com 12U Server Rack Enclosure | In Stock | £375.79 |
