StarTech.com 15U Server Rack Enclosure
Quicklinx: D1V4WS00 Mfr#: RK1520WALHM
10 In Stock
£320.92 ex VAT
£385.10 inc VAT
Use this wall mount network cabinet to mount your server or networking equipment to the wall with a hinged enclosure for easy access. This 15U server or network rack cabinet lets you mount your EIA-310 compliant equipment to the wall, in a secure enclosure that has a hinged rear door for easy access to your equipment. The enclosure features adjustable mounting depth from 2.4 to 20 in. to provide a robust storage solution for your rack-mount equipment.
To provide secure stability for your heaviest equipment, this rack offers 4-post mounting, supporting a higher weight capacity per U than 2-post racks and supporting a total load capacity of up to 200 lbs. (90 kg).
Save valuable floor space by wall-mounting the enclosure. The wall-mounted design makes this enclosure the ideal solution for optimizing equipment storage in your classroom, retail store, server room or office. This rack also includes a 1U shelf that gives you a stable surface for placing equipment that's not rack-mountable or storing your tools.
The wall-mount network rack makes it easy to access your equipment and cabling, with a rear hinge that swings the enclosure away from the wall. By flipping the enclosure 180 degrees upon installation, you can reverse the direction of the hinge so that the enclosure can swing open from left or the right, depending upon your preference.
The 15U network cabinet features a removable and reversible front door and removable side panels, each with quick-release mechanisms, so you can easily access your equipment. Plus, each door and panel on this rack features an independent lock, ensuring your equipment is secure.
For hassle-free cable management, the rack includes a 3 meter roll of hook-and-loop cable tie that makes it easy to keep your cables neat and tidy by binding them together or binding them to the rack. The self-gripping fabric can be cut to any size, enabling a wrap-around solution for the cables of any rack-mount equipment.
This server rack enclosure features heavy-duty steel construction, with lockable doors at all entrances. For hassle-free equipment installation, the mounting rails on the rack can be switched for use with square holes and cage nuts, or tapped rails.
To ensure your equipment is running at an optimal temperature, the server rack/cabinet promotes passive cooling. It features mesh doors and vented top and bottom panels for maximum airflow.
For simple and sturdy mounting, the rack's mounting holes are positioned 16 in. apart, so you can securely attach it to a wall using wall studs.
  • Save space in your office or server room
  • Easily access your servers and network equipment
    The wall-mount network rack makes it easy to access your equipment and cabling, with a rear hinge that swings the enclosure away from the wall. By flipping the enclosure 180 degrees upon installation, you can reverse the direction of the hinge so that the enclosure can swing open from left or the right, depending upon your preference. The 15U network cabinet features a removable and reversible front door and removable side panels, each with quick-release mechanisms, so you can easily access your equipment. Plus, each door and panel on this rack features an independent lock, ensuring your equipment is secure. For hassle-free cable management, the rack includes a 3-meter roll of hook-and-loop cable tie that makes it easy to keep your cables neat and tidy by binding them together or binding them to the rack. The self-gripping fabric can be cut to any size, enabling a wrap-around solution for the cables of any rack-mount equipment.
  • Securely protect your equipment
    This server rack enclosure features heavy-duty steel construction, with lockable doors at all entrances. For hassle-free equipment installation, the mounting rails on the rack can be switched for use with square holes and cage nuts, or tapped rails. To ensure your equipment is running at an optimal temperature, the server rack/cabinet promotes passive cooling. It features mesh doors and vented top and bottom panels for maximum airflow. For simple and sturdy mounting, the rack's mounting holes are positioned 16 in. apart, so you can securely attach it to a wall using wall studs.
StarTech.com 15U 19" Wall Mount Network Cabinet, 16" Deep Hinged Locking IT Network Switch Depth Enclosure, Assembled Vented Computer Equipment Data Rack with Shelf & Flexible Side Panels - 15U Vented Cabinet - rack - 15U
Rack
Rack Type
Cabinet - 4-post
Placing / Mounting
Wall mountable
Package Content
Grounding lug, 2 side panel keys, 2 door keys, 1U shelf, 62 cage nuts (12-24), 62 screws (12-24), 3 metre hook-and-loop cable tie roll
Rack Size
16"
Height (Rack Units)
15U
Product Material
Steel
61 cm x 55.3 cm x 77.2 cm
52 kg
Lockable rear door, key lock, adjustable depth, removable door, reversible front door, threaded hole, adjustable mounting rails
5-year warranty
Rack
Rack Type
Cabinet
Rack Post Qty
4-post
Placing / Mounting
Wall mountable
Product Material
Steel
Package Content
Rack Size
16"
Height (Rack Units)
15U
61 cm
55.3 cm
77.2 cm
52 kg
63.5 cm x 67.5 cm x 85.5 cm / 84 kg
Inner Dimensions
59.6 cm x 54.7 cm x 41 cm
Weight Limit
90 kg
RoHS, REACH, ECA-310-E
Limited warranty: - 5 years
D1V4 StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep In Stock £68.51
D1V4 StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
D1V4 StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
D1V4 StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £30.71
D1V4 StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.44
D1V4 StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
D1V4 StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
D1V4 StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
D1V4 StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £15.50
D1V4 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
D1V4 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.24
D1V4 StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.36
D1V4 StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.59
D1V4 StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £47.16
D1V4 StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.48
D1V4 StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £23.11
D1V4 StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £56.58
D1V4 StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
D1V4 StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
D1V4 StarTech.com 100 Pkg M5 Cage Nuts In Stock £30.81
D1V4 StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
D1V4 StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
D1V4 StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
D1V4 StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
D1V4 StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.01
D1V4 StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.11
D1V4 Startech.com 100 Pkg M6 Mounting Screws In Stock £26.84
D1V4 StarTech.com 19in Cable Management Panel In Stock £24.18
D1V4 StarTech.com 6U Wall-Mount Rack Cabinet In Stock £152.72
D1V4 StarTech.com 26U Server Rack Enclosure In Stock £475.05
D1V4 StarTech.com 9U Wall-Mount Rack Cabinet In Stock £178.89
D1V4 StarTech.com 9U Wall-Mount Rack Cabinet In Stock £198.84
D1V4 StarTech.com 12U Server Rack Enclosure In Stock £338.60
D1V4 StarTech.com 12U Server Rack Enclosure In Stock £283.26
D1V4 StarTech.com 12U Server Rack Enclosure In Stock £385.18
D1V4 StarTech.com Heavy Duty Casters for Server Racks/Cabinets - Set of 4 In Stock £36.61
D1V4 StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
D1V4 StarTech.com 42U Server Rack Cabinet In Stock £1,258.59
