StarTech.com Heavy Duty Casters for Server Racks/Cabinets - Set of 4
Quicklinx: GB6DWS00 Mfr#: RKCASTER2
Hurry, only 2 left in stock!
£35.72 ex VAT
£42.86 inc VAT
Universal Server Rack Casters - Bolt Pattern: 45mm x 75 mm - Hardware Included
This set of four M6 2-inch casters, while designed for StarTech.com racks, can be added to the bottom of any server equipment rack, network rack, A/V rack, etc. with a 45mm x 75mm bolt pattern. Ideal for replacing damaged casters or upgrading a standing rack to a rolling rack for additional mobility. RKCASTER2 is backed by a lifetime warranty and free technical support.
StarTech.com Rack Compatibility
Replacement Casters For:
Optional Casters For*:
[%product id="4POSTRACK12U" text="4POSTRACK12U"%]
[%product id="RK1224WALHM" text="RK1224WALHM"%]
[%product id="4POSTRACK25U" text="4POSTRACK25U"%]
[%product id="RK1232WALHM" text="RK1232WALHM"%]
[%product id="RK1233BKM" text="RK1233BKM"%]
[%product id="RK1520WALHM" text="RK1520WALHM"%]
[%product id="RK1833BKM" text="RK1833BKM"%]
[%product id="RK2620WALHM" text="RK2620WALHM"%]
[%product id="RK2433BKM" text="RK2433BKM"%]
[%product id="RK616WALM" text="RK616WALM"%]
[%product id="RK2537BKM" text="RK2537BKM"%]
[%product id="RK9WALM" text="RK9WALM"%]
[%product id="RK4242BK24" text="RK4242BK24"%]
[%product id="RK4242BK30" text="RK4242BK30"%]
*Optional casters are sold separately.
  • 2-inch caster wheels
    Four-pack of universal swivel casters can be used as replacements on portable/mobile 4-post racks such as RK1833BKM, RK2433BKM, RK4242BK24 or to convert a floor rack to a rolling rack when casters are not included.
  • Heavy-duty load capacity
    Tested to 1.6 times their rated load capacity to ensure performance, these heavy-duty casters/wheels, can individually support up to a stationary load of 550 lbs. (250 kg) or a rolling load of 165 lbs. (75 kg).
  • 45mm x 75mm bolt pattern
    This caster kit can be used on any rack with a 45mm x 75mm bolt pattern to replace damaged casters and upgrade a floor rack to a rolling rack for additional mobility.
StarTech.com Heavy Duty Casters for Server Racks/Cabinets, Set of 4 Universal M6 2-inch Swivel Caster Kit, 45x75mm Pattern, Replacement Caster Wheels for 4 Post Racks, Steel/Plastic - 4-Pack Rolling Caster Kit (RKCASTER2) - rack casters kit
Rack casters kit
Package Content
4 casters, 18 M6 screws, 18 M6 flat washers, 18 M6 cage nuts
Black, silver
Product Material
Cold-rolled steel, plastic
6.5 cm x 9.2 cm x 7.25 cm
2.4 kg
Rack casters kit
Product Material
Package Content
6.5 cm
9.2 cm
7.25 cm
Diameter
50 mm
2.4 kg
22.5 cm x 12.5 cm x 9 cm / 2.6 kg
Black, silver
Weight Limit
250 kg
RoHS
Limited warranty: - lifetime
GB6D StarTech.com 42U Adjustable Depth Open Frame 4 Post Server Rack Cabinet - Casters Levelers and Hooks In Stock £203.32
GB6D StarTech.com 25U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks In Stock £192.50
GB6D StarTech.com 12U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks In Stock £165.22
GB6D StarTech.com 12U Server Rack Cabinet In Stock £404.63
GB6D StarTech.com 18U Server Rack Cabinet In Stock £421.07
GB6D StarTech.com 24U Server Rack Cabinet In Stock £595.67
GB6D StarTech.com 6U Wall-Mount Rack Cabinet In Stock £148.99
GB6D StarTech.com 26U Server Rack Enclosure In Stock £470.78
GB6D StarTech.com 9U Wall-Mount Rack Cabinet In Stock £174.53
GB6D StarTech.com 12U Server Rack Enclosure In Stock £330.35
GB6D StarTech.com 15U Server Rack Enclosure In Stock £313.10
GB6D StarTech.com 25U Server Rack Cabinet In Stock £875.30
GB6D StarTech.com 12U Server Rack Enclosure In Stock £375.79
