StarTech.com HDMI to VGA Video Adapter Converter with Audio - HD to VGA Monitor 1080p
Quicklinx: 7B5KWS00 Mfr#: HDMI2VGA
Type: HDMI
Hurry, only 1 left in stock!
£13.92 ex VAT
£16.70 inc VAT
Connect HDMI devices to a VGA monitor with stereo audio separation. The HDMI2VGA HDMI to VGA converter converts digital HDMI or DVI video signals to analog VGA, taking the input resolution from your device and converting it into an analog signal at the same resolution.
The converter also separates the audio stream from the HDMI signal (HDMI LPCM-2 Channel) and converts it to analog stereo audio that can be used with the VGA display.
With support for resolutions of up to 1080p, the HDMI2VGA converter is a perfect solution for connecting video cards (desktop or laptop) or consumer electronics devices such as game consoles or home theater receivers that offer an HDMI Out port to a VGA display.
The HDMI2VGA adapter/converter is simple to use, with no complicated settings.
StarTech.com HDMI® to VGA Video Adapter Converter with Audio - HD to VGA Monitor 1920x1200 1080p - HDMI to VGA HD15 (HDMI2VGA) - video converter - black
Video converter
Graphics Engine
- up to
Max Resolution
1920 x 1200
1 x HDMI input - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x component video output - RCA x 3 (on supplied cable) , 1 x audio line-out - mini-phone stereo 3.5 mm
7.6 cm x 7.6 cm x 9.2 cm
Enclosure Colour
Video converter
Max Resolution
1920 x 1200
1 x HDMI input - 19 pin HDMI Type A - female , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female , 1 x component video output - RCA x 3 (on supplied cable) - male , 1 x audio line-out - mini-phone stereo 3.5 mm - female
AC 120/230 V
1 x VGA / component video adapter
FCC, RoHS
7.6 cm
7.6 cm
9.2 cm
172 g
Enclosure Colour
0 - 60%
7B5K StarTech.com 6 ft 3.5mm Stereo Audio Cable - M/M In Stock £4.64
7B5K StarTech.com 6 ft 3.5mm Stereo Extension Audio Cable - M/F In Stock £4.94
7B5K StarTech.com 12 ft PC Speaker Extension Audio Cable In Stock £5.05
7B5K StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
7B5K StarTech.com HDMI to VGA Video Adapter Converter with Audio - HD to VGA Monitor 1080p In Stock £13.92
7B5K StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.00
7B5K StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.63
7B5K StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.78
7B5K StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £4.91
7B5K StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 In Stock £22.81
7B5K StarTech.com Micro HDMI to VGA Adapter Converter for Smartphones / Ultrabook / Tablet - 1920x1080 In Stock £22.95
7B5K StarTech.com HDMI to VGA Video Adapter Converter with Audio for Desktop PC / Laptop / Ultrabook In Stock £16.15
7B5K StarTech.com Compact HDMI to VGA Adapter Converter - Ideal for Chromebooks Ultrabooks & Laptops In Stock £14.78
7B5K StarTech.com VGA to HDMI Adapter with USB Audio & Power- Portable VGA to HDMI Converter 1080p In Stock £36.47
7B5K StarTech.com 6ft HDMI to VGA adapter cable In Stock £20.08
7B5K StarTech.com DC Power Adapter - 5V, 3A In Stock £11.96
7B5K StarTech.com HDMI to RCA Converter Box In Stock £62.76
Type: HDMI
