Connect an HDMI equipped Laptop, Ultrabook, or Desktop Computer to your VGA Display, or Projector. The HD2VGAE HDMI to VGA Adapter/Converter actively converts an HDMI video source from your laptop, ultrabook, or Desktop computer onto a VGA HD15 projector or display.
With no need for an external power source, and support for resolutions up to 1080p (1920x1080), this active HDMI to VGA HD15 adapter offers a compact and portable solution.
- StarTech.com 1080p 60Hz HDMI to VGA High Speed Display Adapter - Active HDMI to VGA (Male to Female) Video Converter for Laptop/PC/Monitor (HD2VGAE2) - video converter - black
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x HDMI input - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15)
- 4 cm x 24.5 cm x 1.5 cm
- Enclosure Colour
- Black
- 2-year warranty
- Video converter
- Max Resolution
- 1920 x 1200 at 60 Hz
- 1 x HDMI input - 19 pin HDMI Type A - male , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female
- FCC, RoHS
- 4 cm
- 24.5 cm
- 1.5 cm
- 39 g
- Enclosure Colour
- Black
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 40 - 85% (non-condensing)
