This HDMI to DisplayPort adapter connects a 4K 60Hz HDMI video source, such as a laptop or desktop, to a DisplayPort monitor or projector.
4K 60Hz Resolution
This 1ft (30cm) HDMI to DisplayPort adapter supports up to 3840x2160 60Hz with HDR, HDCP 2.2, and 2-channel DisplayPort audio. In addition, it supports 4K 30hz, 1080p, and ultrawide resolutions up to 3440x1440 60Hz. If connected to a 4K 30Hz or less source device, the output resolution will be equivalent to the input. -
Extended Cables
The HDMI to DP converter features a 1ft (30cm) cable between the HDMI and DP connectors, reducing strain on ports and connectors. The adapter includes an attached 1ft (30cm) USB-A cable for connecting to a nearby powered USB port or a USB wall charger. -
Comprehensive Compatibility
Plug and play setup is compatible with any HDMI enabled laptop, desktop, Ultrabook, MacBook, or Chromebook. The HDMI to DP Adapter utilizes the video capabilities of the host device, reducing CPU usage that may occur with driver-based video adapters. Works with any operating system, including Windows, macOS, Ubuntu, and ChromeOS. This product is backed for 3-years by StarTech.com, including free 24/5 multi-lingual technical assistance .
- StarTech.com 1ft (30cm) HDMI to DisplayPort Adapter, Active 4K 60Hz HDMI Source to DP Monitor Adapter Cable, USB Bus Powered, HDMI 2.0 to DisplayPort Converter for Laptops/PC - Supports HDR and Ultrawide Displays (128-HDMI-DISPLAYPORT) - adapter cable - DisplayPort / HDMI - 30 cm
- Cable
- Adapter cable - DisplayPort / HDMI
- Max Output Resolution
- 3840 x 2160 - 60 Hz
- Length
- 30 cm
- Grey, black
- Connectors
- HDMI - male (input) , USB (power only) - male
- Connectors (Second End)
- DisplayPort - female (output)
- DisplayPort 1.2
- Active cable, 4K60Hz (3840 x 2160) support, one directional
- 3-year warranty
- Cable Type
- Adapter cable active, 4K60Hz (3840 x 2160) support, one directional
- Interface Supported
- DisplayPort 1.2
- Length
- 30 cm
- HDR support, USB powered, LT6711A chipset, 2 audio channels
- Grey, black
Adapters & Converters
- 3840 x 2160
- Refresh Rate
- 60 Hz
- OS Required
- Apple MacOS, Microsoft Windows, Ubuntu, Google Chrome OS
- Connectors
- 19 pin HDMI Type A - male (input) , 4 pin USB Type A (power only) - male
- 20 pin DisplayPort (1.2) - female (output)
- Plug and Play, RoHS, WEEE, HDCP 2.2
- 38 g
- Shipping Width
- 22.5 cm
- Shipping Depth
- 12.5 cm
- Shipping Height
- 1.3 cm
- Shipping Weight
- 43 g
- Limited warranty - 3 years
StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £3.97 |
StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.22 |
StarTech.com 3ft DisplayPort 1.4 8K 60Hz | In Stock | £15.34 |
StarTech.com 6ft DisplayPort 1.4 8K 60Hz | In Stock | £16.65 |
StarTech.com 10ft DisplayPort 1.4 8K 60Hz | In Stock | £32.62 |
