- StarTech.com 10ft (3m) VESA Certified DisplayPort 1.4 Cable, 8K 60Hz HDR10, Ultra HD 4K 120Hz DP Video Cable, DisplayPort to DisplayPort Cable, DP Cord for Monitors/Displays, M/M - DP 1.4 Cable with Latches (DP14VMM3M) - DisplayPort cable - DisplayPort to DisplayPort - 3 m
- DisplayPort cable
- Technology
- Shielded
- Molded, passive cable, 8K60Hz (7680 x 4320) support, 4K120Hz (3840 x 2160) support, strain relief, HBR3 support, Display Stream Compression 1.2 (DSC), DisplayPort Multi-Stream Transport (MST), 32 audio channels, HDR10 support, 7.1 audio channel support, Chroma subsampling (4:4:4), 32.4 Gbps data rate, Forward Error Correction, 5.1 audio channel support
- Length
- 3 m
- Connector
- 20 pin DisplayPort - male
- Connector (Second End)
- DisplayPort 1.4
- Grey, black
- Limited lifetime warranty
- DisplayPort cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Gold
- Length
- 3 m
- Outside Diameter
- 7.5 mm
- Grey, black
- Connector
- DisplayPort 1.4, RoHS, HDCP 2.2, 8K VESA certified
- Shipping Width
- 33 cm
- Shipping Depth
- 25.5 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 253 g
