StarTech.com HDMI to DisplayPort Adapter
Quicklinx: H136WS00 Mfr#: 128-HDMI-DISPLAYPORT
Length: 30cm
19 In Stock
£50.14 ex VAT
£60.16 inc VAT
This HDMI to DisplayPort adapter connects a 4K 60Hz HDMI video source, such as a laptop or desktop, to a DisplayPort monitor or projector.
  • 4K 60Hz Resolution
    This 1ft (30cm) HDMI to DisplayPort adapter supports up to 3840x2160 60Hz with HDR, HDCP 2.2, and 2-channel DisplayPort audio. In addition, it supports 4K 30hz, 1080p, and ultrawide resolutions up to 3440x1440 60Hz. If connected to a 4K 30Hz or less source device, the output resolution will be equivalent to the input.
  • Extended Cables
    The HDMI to DP converter features a 1ft (30cm) cable between the HDMI and DP connectors, reducing strain on ports and connectors. The adapter includes an attached 1ft (30cm) USB-A cable for connecting to a nearby powered USB port or a USB wall charger.
  • Comprehensive Compatibility
    Plug and play setup is compatible with any HDMI enabled laptop, desktop, Ultrabook, MacBook, or Chromebook. The HDMI to DP Adapter utilizes the video capabilities of the host device, reducing CPU usage that may occur with driver-based video adapters. Works with any operating system, including Windows, macOS, Ubuntu, and ChromeOS. This product is backed for 3-years by StarTech.com, including free 24/5 multi-lingual technical assistance .
StarTech.com 1ft (30cm) HDMI to DisplayPort Adapter, Active 4K 60Hz HDMI Source to DP Monitor Adapter Cable, USB Bus Powered, HDMI 2.0 to DisplayPort Converter for Laptops/PC - Supports HDR and Ultrawide Displays (128-HDMI-DISPLAYPORT) - adapter cable - DisplayPort / HDMI - 30 cm
Cable
Adapter cable - DisplayPort / HDMI
Max Output Resolution
3840 x 2160 - 60 Hz
Length
30 cm
Grey, black
Connectors
HDMI - male (input) , USB (power only) - male
Connectors (Second End)
DisplayPort - female (output)
DisplayPort 1.2
Active cable, 4K60Hz (3840 x 2160) support, one directional
3-year warranty
Cable Type
Adapter cable active, 4K60Hz (3840 x 2160) support, one directional
Interface Supported
DisplayPort / HDMI
DisplayPort 1.2
Length
30 cm
HDR support, USB powered, LT6711A chipset, 2 audio channels
Grey, black
Adapters & Converters
3840 x 2160
Refresh Rate
60 Hz
Apple MacOS, Microsoft Windows, Ubuntu, Google Chrome OS
Connectors
19 pin HDMI Type A - male (input) , 4 pin USB Type A (power only) - male
20 pin DisplayPort (1.2) - female (output)
Plug and Play, RoHS, WEEE, HDCP 2.2
38 g
Shipping Width
22.5 cm
Shipping Depth
12.5 cm
Shipping Height
1.3 cm
Shipping Weight
43 g
Limited warranty - 3 years
H136 StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.06
H136 StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.29
H136 StarTech.com 3ft DisplayPort 1.4 8K 60Hz In Stock £14.26
H136 StarTech.com 6ft DisplayPort 1.4 8K 60Hz In Stock £14.98
H136 StarTech.com 10ft DisplayPort 1.4 8K 60Hz In Stock £20.57
H136 StarTech.com HDMI to DP Adapter, 8K 60Hz In Stock £42.21
Length: 30cm
