StarTech.com HDMI to DisplayPort, VGA or DVI Adapter
Quicklinx: C7C2WS00 Mfr#: HD2DPVGADVI
£57.85 ex VAT
£69.42 inc VAT
Keep this compact adapter with your laptop while you're traveling, to connect to virtually any monitor, television or projector. This travel adapter lets you connect your HDMI enabled Ultrabook or laptop computer to any DisplayPort, VGA or DVI display. To ensure compatibility with your computer, the adapter has been engineered to support both Windows and Mac computers.
This 3-in-1 adapter gives you all the video outputs you need to connect to any projector or display. With DisplayPort, VGA and DVI outputs, this adapter lets you connect from your laptop's HDMI port to any boardroom or classroom display, without the inconvenience of carrying a separate adapter for each display type.
With support for multiple video outputs and a lightweight, small-footprint design, this adapter is the perfect solution for traveling professionals, such as sales representatives or instructors. The 3-in-1 A/V adapter is also great for BYOD (Bring Your Own Device) applications around the office.
The adapter features plug-and-play installation, enabling you to quickly and easily connect to almost any display you come across, so you can focus on the finer details of your presentation and not the technical details of a boardroom's A/V setup. It's USB powered, which means a power adapter is not required, making the adapter easier to carry. Plus, you can just plug the adapter into your computer, instead of having to find an additional power source.
The DisplayPort output on this adapter supports Ultra HD 4K resolutions, providing four times the picture quality of high-definition 1080p. The DP output is also backward compatible with lower resolutions, such as 1080p and 720p, so the adapter is also perfect for your legacy video equipment. The VGA and DVI outputs also support a high-definition maximum resolution up to 1920 x 1200, so you can still enjoy excellent video quality.
Note: This adapter will not output digitally encrypted content through the VGA port.
StarTech.com Travel A/V Adapter: HDMI to DisplayPort VGA or DVI - 1920x1200 - video converter
Video converter
Max Resolution
1920 x 1200
1 x HDMI input - 19 pin HDMI Type A , 1 x USB (power only) - 4 pin USB Type A (power only) , 1 x DisplayPort output - 20 pin DisplayPort , 1 x DVI-I output - 24+5 pin combined DVI , 1 x VGA output - 15 pin HD D-Sub (HD-15)
Video converter
Max Resolution
1920 x 1200
1 x HDMI input - 19 pin HDMI Type A - male , 1 x USB (power only) - 4 pin USB Type A (power only) - male , 1 x DisplayPort output - 20 pin DisplayPort - female , 1 x DVI-I output - 24+5 pin combined DVI - female , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female
HD/4k Ready
FCC, RoHS, RCM, DisplayPort 1.2
70 °C
40 - 50%
C7C2 StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £6.05
C7C2 StarTech.com 6 ft DVI-D Single Link Cable - M/M In Stock £6.77
C7C2 StarTech.com 15 ft DVI-D Single Link Cable - M/M In Stock £13.55
C7C2 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £15.85
C7C2 StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F In Stock £10.93
C7C2 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £12.20
C7C2 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.69
C7C2 StarTech.com 10 ft DVI-D Single Link Cable - M/M In Stock £7.89
C7C2 StarTech.com HDMI or DVI to DisplayPort Active Converter In Stock £65.59
C7C2 StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter In Stock £19.37
C7C2 StarTech.com DisplayPort to HDMI - 4K In Stock £14.14
C7C2 StarTech.com HDMI to DisplayPort Converter - 4K In Stock £34.49
C7C2 StarTech.com HDMI to DisplayPort, VGA or DVI Adapter In Stock £57.85
Price Range Ex VAT: 50 - 100
