StarTech.com DisplayPort to HDMI - 4K
Quicklinx: BKBXWS00 Mfr#: DP2HD4KADAP
More than 50 In Stock
£12.54 ex VAT
£15.04 inc VAT
Connect your 4K HDMI display to a DP video source using this compact, passive adapter. This DisplayPort to HDMI adapter supports 4K video resolution, enabling you to connect DisplayPort devices, such as an Ultrabook or desktop computer, to a 4K HDMI display or projector.
You will be amazed at how this adapter flawlessly manages your graphics-intensive content. With support for resolutions up to 4K - four times the resolution of high-definition 1080p - its lossless performance makes the adapter the ideal solution for high-resource applications such as graphic design, CAD & CAM design, or health care imaging (MRI, radiology diagnostics, etc.).
Plus, the 4K adapter supports 1080p displays, which makes it a great accessory for home, office or other workspace applications.
This DP to HDMI adapter is extremely portable, with a lightweight, small-footprint design. It's the perfect accessory to carry with your Ultrabook, fitting easily into your laptop bag or carrying case. Its ultra-portable design makes the adapter ideal for BYOD (Bring Your Own Device) applications at the office, and enables you to arrive prepared when you're presenting to a potential client, teaching off-site, or traveling to meet with a customer.
  • Astonishing 4K picture quality
    You will be amazed at how this adapter flawlessly manages your graphics-intensive content. With support for resolutions up to 4K - four times the resolution of high-definition 1080p - its lossless performance makes the adapter the ideal solution for high-resource applications such as graphic design, CAD & CAM design, or health care imaging (MRI, radiology diagnostics, etc.). Plus, the 4K adapter supports 1080p displays, which makes it a great accessory for home, office or other workspace applications.
  • Arrive prepared, wherever you go
    This DP to HDMI adapter is extremely portable, with a lightweight, small-footprint design. It's the perfect accessory to carry with your Ultrabook, fitting easily into your laptop bag or carrying case. Its ultra-portable design makes the adapter ideal for BYOD (Bring Your Own Device) applications at the office, and enables you to arrive prepared when you're presenting to a potential client, teaching off-site, or traveling to meet with a customer. The DP2HD4KADAP is backed by a 3-year StarTech.com warranty and free lifetime technical support.
StarTech.com Displayport to HDMI Adapter - 4K30 - DPCP & HDCP - DisplayPort 1.2 to HDMI 1.4 - Apple HDMI Adapter (DP2HD4KADAP) - adapter - DisplayPort / HDMI
Cable
Adapter - DisplayPort / HDMI
Max Output Resolution
3840 x 2160 - 30 Hz
Connector
DisplayPort - male
Connector (Second End)
HDMI - female
DisplayPort 1.2/DisplayPort++
Passive adapter, 4K30Hz (3840 x 2160) support
3-year warranty
P/N: TB2DOCK4K2DP
Cable Type
Adapter passive, 4K30Hz (3840 x 2160) support
Interface Supported
DisplayPort / HDMI
DPCP compliant, 7.1 channel Surround Sound
Adapters & Converters
3840 x 2160
Refresh Rate
30 Hz
Apple MacOS, Microsoft Windows, Ubuntu
Connector
20 pin DisplayPort - male
19 pin HDMI Type A - female
FCC, RoHS, HDCP 1.4
2.1 cm
6.4 cm
1.1 cm
7.5 g
Shipping Width
9.8 cm
Shipping Depth
14.5 cm
Shipping Height
2.6 cm
Shipping Weight
36 g
Limited warranty - 3 years
P/N: TB2DOCK4K2DP
BKBX StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £11.19
BKBX StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F In Stock £10.81
BKBX StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £9.22
BKBX StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £13.22
BKBX StarTech.com HDMI or DVI to DisplayPort Active Converter In Stock £59.29
BKBX StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £9.00
BKBX StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.74
BKBX StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter In Stock £19.96
BKBX StarTech.com 6 ft DP to HDMI cable - 4K In Stock £15.82
BKBX StarTech.com DisplayPort to HDMI - 4K In Stock £12.54
BKBX StarTech.com HDMI to DisplayPort Converter - 4K In Stock £34.32
