StarTech.com HDMI Over Single Cat 5e / 6 Extender with Power Over Cable - 230 ft (70m)
Quicklinx: 8WRWWS00 Mfr#: ST121HDBTE
More than 50 In Stock
£187.84 ex VAT
£225.40 inc VAT
Extend HDMI up to 230ft (70m) over a single CAT5e/6 cable with Power over Cable to Receiver. The StarTech.com HDBaseT extender kit, extends HDMI up to 230 feet (70 Meters) over a single CAT5e or CAT6 cable. The extender supports Ultra HD and Full HD resolutions (4K / 1080p) with support for 3D and the accompanying digital audio. For added versatility, both the transmitter and receiver can be powered by the same single power source using Power Over Cable (POC). The versatility of this video extender makes it an ideal solution for digital signage applications in large buildings such as commercial shopping centers, stadiums, schools, and hospitals.
HDBaseT is a standardized, zero latency, video distribution technology that's revolutionizing HDMI distribution. HDBaseT uses an advanced method of modulation that enables you to distribute uncompressed HDMI audio and video along with additional signals such as 100BaseT Ethernet, IR, RS-232 serial and power over cable.
The extender offers HDBaseT technology with HDMI and Power in a single extender kit, for complete end-to-end solution. Offering greater versatility than traditional HDMI extenders or HDMI cabling alone HDBaseT is the clear choice for every integrator and system designer. The added benefit of power over cable means you'll only need one power source at either side of your extension, great for extending video to areas where power outlets may be limited, such as industrial sites.
With the A/V industry quickly adopting 4K as the new high-resolution video standard, long range video distribution can be a challenge with standard HDMI cables beginning signal degradation at 30 feet.
With support for 4K you'll be amazed at how HDBaseT maintains your Ultra HD picture quality, four times the resolution of high-definition 1080p, even at 130 feet away from your video source. Plus, because the extender supports High-Definition 1080p and lower resolutions at 230 feet away, you can comfortably use this extender to make any video source look great, while future proofing your setup for 4K implementation.
This extender has been specially crafted for a smooth, tidy installation. HDBaseT technology allows for single cable installation, for seamless integration using existing CAT5e or CAT6 infrastructure, avoiding the hassle of running multiple Ethernet cables while, reducing potential failure points. Plus, the added benefit of power over cable means you'll only need one power source to power both your extender and receiver, great for extending to areas where power outlets may be limited. Mounting hardware is also included for both the extender and receiver for discrete, professional mounting.
  • Reliable performance
    This extender is built to operate in environments with temperatures ranging from 0°C to 40°C, ensuring stable functionality under various conditions.
  • Impressive video quality
    Supports a maximum video resolution of 4096 x 2160, providing sharp images and clear details for an enhanced viewing experience.
  • Long-distance transmission
    Capable of transmitting signals up to 70 m, it allows for flexibility in installations where devices are located far from each other.
  • Standards compliant
    Meets FCC and RoHS standards, ensuring that it adheres to regulatory guidelines for safety and environmental impact.
  • Simple connectivity
    Utilizes wired technology, making installation straightforward and reducing potential connectivity issues often associated with wireless systems.
StarTech.com HDMI over CAT5e / CAT6 Ethernet Extender with HDBaseT - 4K@115ft, 1080p@230ft - HDMI Video Transmitter and Receiver Kit w/ POC (ST121HDBTE) - video/audio extender
Video/audio extender
External
Transmission Medium
CAT 5e/6
Max Transfer Distance
70 m
AC 120/230 V
6.7 cm x 8 cm x 2.5 cm
310 g
P/N: ST121HDBTRP, ST124HD4K, SVA12M2NEUA, SVA12M5NA
External
Wired
Max Resolution
4096 x 2160 @ 30 Hz
70 m
1 x HDMI
FCC, RoHS
External power adapter
AC 120/230 V
6.7 cm
8 cm
2.5 cm
310 g
0 - 80% (non-condensing)
8WRW StarTech.com 75 ft Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £25.96
8WRW StarTech.com 75ft Orange Cat6 Patch Cable In Stock £25.91
8WRW StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £15.73
8WRW StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.74
8WRW StarTech.com HDMI Over Single Cat 5e / 6 Extender with Power Over Cable - 230 ft (70m) In Stock £187.84
8WRW StarTech.com HDMI Over CAT5/CAT6 Extender with Power Over Cable - 165 ft (50m) In Stock £92.94
8WRW StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.78
8WRW StarTech.com HDMI Over CAT5e / CAT6 Extender with Power Over Cable - 330 ft (100m) In Stock £318.01
8WRW StarTech.com HDMI over CAT6 with USB - 50m In Stock £167.96
8WRW StarTech.com HDBaseT Extender Kit - 4K In Stock £281.16
8WRW StarTech.com DC Power Adapter - 12V, 2A In Stock £11.76
8WRW StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
8WRW StarTech.com 4K 60Hz HDBaseT extender - 70m (100m @ 1080) In Stock £383.53
8WRW StarTech.com 4K HDMI Extender, 4K 60Hz HDR In Stock £165.60
