StarTech.com HDMI over CAT6 with USB - 50m
Quicklinx: BVV5WS00 Mfr#: ST121USBHD
£167.96 ex VAT
£201.55 inc VAT
Extend 1080p video and four USB peripheral devices to a remote location. This HDMI extender kit lets you transmit your 1080p HD video source to your remote HDMI display at distance of up to 165 ft. away (50 m) using shielded CAT6 cabling. The extender features a built-in 4-port USB 2.0 hub that also lets you connect four remote USB peripheral devices at your display location.
Using this HDMI extender, you can maintain the quality of your high-definition video signal along with the accompanying 7.1 digital audio, even at 165 feet away from your source device. The extender supports resolutions up to 1920x1200 or 1080p - perfect for dazzling your audience in remote digital-signage applications in hospitals or at shopping centers.
The built-in 4-port USB 2.0 hub lets you remotely connect, access or control up to four USB devices located at your remote display - great for flash drives, printers, scanners, external hard drives and I/O devices. Remote USB extension also enables you to remotely control your source device, which is ideal for adding touchscreen interfaces at your display in market or POS kiosks.
For hassle-free setup the HDMI extender offers easy plug-and-play installation with no additional software or drivers required. Plus, the extender passes the EDID information included in your HDMI signal, and automatically adjusts video equalization ensuring you won't have to configure it manually. Mounting hardware is also included, for a tidy and professional installation.
To maximize performance this extender requires shielded CAT6 cable. When using unshielded CAT6 cable the maximum distance is reduced to 30m. When using CAT5 cable the maximum distance is reduced to 15m.
StarTech.com HDMI over CAT6 Extender with 4-port USB Hub - Remote HDMI over CAT5 or CAT6 - 165 ft (50m) - 1080p (ST121USBHD) - video/audio/infrared/USB extender
Video/audio/infrared/USB extender
External
Australia, North America, United Kingdom, Europe
Data Transfer Rate
3.4 Gbps
Transmission Medium
CAT 6
Max Transfer Distance
50 m
External
Built-in Devices
USB Hub
Wired
Data Transfer Rate
3.4 Gbps
50 m
7.1 channel audio support, Dolby TrueHD support
1 x HDMI (input) - 19 pin HDMI Type A female , 1 x HDMI (output) - 19 pin HDMI Type A female , 4 x USB 2.0 - Type A female , 1 x mini-USB 2.0 (input) - Type B female , 2 x mini-USB 2.0 (output) - Type B female
2 x network cable , 2 x mini-USB to USB cable
Mounting Kit
Included
FCC, RoHS, WEEE, RCM
External power adapter
Installed Qty
1
BVV5 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
BVV5 StarTech.com HDMI Over Single Cat 5e / 6 Extender with Power Over Cable - 230 ft (70m) In Stock £190.80
BVV5 StarTech.com HDMI Over CAT5/CAT6 Extender with Power Over Cable - 165 ft (50m) In Stock £92.94
BVV5 StarTech.com HDMI Over CAT5e / CAT6 Extender with Power Over Cable - 330 ft (100m) In Stock £318.01
