This HDMI over IP extender kit distributes video to a remote location, over your local area network (LAN) and Cat5 or Cat6 Ethernet cabling. By combining this kit with additional receivers (sold separately) and an Ethernet switch (sold separately) you can distribute an HDMI source to multiple locations and create video walls using several remote displays and receivers in the same location.
You can also use multiple transmitters on the same network to distribute different video sources or connect the transmitter directly to a receiver at up to 330 ft. (100 m), in a point-to-point setup. Remote control of serial devices is supported through RS-232 extension.
With support for video resolutions up to 1080p (1920 x 1080 at 60Hz), the transmitter also supports digital and analog audio to the receiver and analog audio from the receiver to the transmitter.
The kit includes an easy-to-use online app to manage your IP video distribution.
The app is available on iOS for an iPhone or iPad, Android for a smartphone or tablet, and Google Chrome browser for a desktop.
The HDMI transmitter/receiver kit includes optional shelf-mounting hardware. It uses Cat5e or Cat6 cables and works with existing network infrastructures, eliminating the expense of running proprietary cables.
Resolutions up to 1080p, with Audio
With support for video resolutions up to 1080p (1920 x 1080 at 60Hz), the transmitter also supports digital and analog audio to the receiver and analog audio from the receiver to the transmitter. -
Mobile Control Through a Free App
The kit includes an easy-to-use online app to manage your IP video distribution. The app is available on iOS for an iPhone or iPad, and Android for a smartphone or tablet. Download the StarTech.com Video Control software to manage your IP video distribution. NOTE: Your router must support IGMP snooping. Please refer to your network switch or router documentation to ensure IGMP snooping is supported and enabled. -
Hassle-Free Installations
The HDMI transmitter/receiver kit includes optional shelf-mounting hardware. It uses Cat5e or Cat6 cables and works with existing network infrastructures, eliminating the expense of running proprietary cables. ST12MHDLAN2K is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com HDMI over IP Extender Kit with Video Wall Support - 1080p - HDMI over CAT5e / CAT6 Transmitter and Receiver Kit (ST12MHDLAN2K) - video/audio/infrared/serial extender - HDMI - TAA Compliant
- Video/audio/infrared/serial extender
- Form Factor
- External
- Localisation
- North Asia, Japan, Europe, United Kingdom, Australia, New Zealand
- Data Link Protocol
- HDMI
- Max Transfer Distance
- 100 m
- Power
- AC 120/230 V
- 11.8 cm x 13.1 cm x 3.1 cm
- 80 g
- TAA Compliant
- 2-year warranty
- Designed For
- P/N: ST12MHDLAN2R
- Form Factor
- External
- Black
- Localisation
- Connectivity Technology
- Wired
- HDMI
- Max Resolution
- 1920 x 1080 @ 60 Hz
- 100 m
- Status Indicators
- Power, link OK, status
- Daisy-chaining support, wall mountable
- 1 x HDMI (input) - 19 pin HDMI Type A female , 1 x HDMI (output) - 19 pin HDMI Type A female , 2 x RS-232 (input) - RJ-11 , 2 x RS-232 (output) - RJ-11 , 2 x IrDA (input) - mini jack , 2 x IrDA (output) - mini jack , 2 x audio (input) - mini jack , 2 x audio (output) - mini jack
- Included Accessories
- IR receiver, IR transmitter, 8 foot pads
- Cables Included
- 1 x network cable , 2 x RJ-11 to RS-232 adapter , 2 x RJ-11 phone cable
- Mounting Kit
- Included
- Rack Mounting Kit
- Included
- RoHS, FCC
- TAA Compliant
- Power Device
- External power adapter
- Max Supported Qty
- 2
- Voltage Required
- AC 120/230 V
- 10 Watt
- 11.8 cm
- 13.1 cm
- 3.1 cm
- 80 g
- Shipping Weight
- 200 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80%
- Designed For
- P/N: ST12MHDLAN2R
StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M | In Stock | £7.68 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £15.86 |
StarTech.com HDMI Over IP Extender Kit - 4K | In Stock | £506.11 |
StarTech.com ST12MHDLAN4K Receiver | In Stock | £253.06 |
StarTech.com Video Wall Mount - Steel | In Stock | £290.72 |
StarTech.com HDMI over IP Extender - 1080p | In Stock | £357.01 |
StarTech.com HDMI KVM Extender over LAN - 4K 30Hz | In Stock | £524.19 |
