StarTech.com HDMI KVM Extender over LAN - 4K 30Hz
Quicklinx: FC0CWS00 Mfr#: SV565HDIP
Hurry, only 1 left in stock!
£528.94 ex VAT
£634.72 inc VAT
This HDMI KVM extender kit lets you use a keyboard, mouse and monitor to remotely control any computer over your IP-enabled local area network (LAN). Combined with a KVM switch, the KVM console extender can be used with multiple computers. The extender features four USB ports that enable you to connect other USB devices, in addition to your keyboard and mouse.
The HDMI KVM extender delivers astonishing 4K UHD picture quality to your remote display with support for resolutions up to 3840 x 2160p at 60Hz.
With a transmitter and a receiver, the KVM extender provides a complete end-to-end solution that supports mounting for tidy installation. Plus, it uses standard CAT5e or CAT6 Ethernet cable, eliminating the expense and hassle of specialized cables and enabling you to use existing network infrastructure.
The extender supports EDID pass-through, ensuring your computer can automatically configure optimal settings for your display over your LAN.
The extender uses your local intranet to connect your computers to your remote workstation. You can connect additional receivers (sold separately) to distribute your HDMI signal to multiple displays in your remote location, or combine the source to create a video wall that expands your single video source across multiple displays.
For smaller-scale applications, you can connect the transmitter and receiver units directly over CAT5 or CAT6 cabling up to 330 feet (100 meters).
  • Robust connectivity options
    This KVM extender supports HDMI, USB 2.0, and external network connections, allowing seamless integration into existing systems.
  • Extensive distance coverage
    With a maximum transfer distance of 100 m over standard network cables, this device offers flexibility for remote setups.
  • High durability
    Featuring a mean time between failures (MTBF) of 60,000 hours, this product is built to provide reliable performance.
  • Environmentally compliant
    The extender meets various compliance standards such as FCC, RoHS, and WEEE, ensuring it adheres to environmental safety regulations.
  • Enhanced audio capabilities
    Supporting 7.1 channel audio, this product ensures a rich audio experience along with high-quality video transmission.
StarTech.com HDMI KVM Extender over IP Network - 4K 30Hz HDMI and USB over IP LAN or Cat5e/Cat6 Ethernet (100m/330ft) - Remote KVM Console - video/audio extender - HDMI - TAA Compliant
Video/audio extender
External
Data Transfer Rate
12 Mbps
HDMI
Max Transfer Distance
100 km
AC 100 - 240 V
11.7 cm x 13 cm x 2.8 cm
610 g
TAA Compliant
External
Wired
HDMI
Data Transfer Rate
12 Mbps
Max Resolution
3840 x 2160 @ 30 Hz
100 km
Status Indicators
Video, connection status
7.1 channel audio support, EDID Pass-Through
1 x HDMI (input) - 19 pin HDMI Type A female , 1 x network (input) - RJ-45 , 2 x network (input) - RJ-11 , 1 x USB (input) - mini-USB Type B , 2 x audio (input) female , 2 x (input) - mini jack female , 1 x HDMI (output) - 19 pin HDMI Type A female , 1 x network (output) - RJ-45 , 2 x network (output) - RJ-11 female , 2 x USB 2.0 (output) - Type A female , 2 x USB (output) - Type A , 2 x audio (output) female , 2 x (output) - mini jack female
8 rubber feet, screwdriver, 2 x DB9 serial adapters
2 x network cable , 2 x serial cable , 1 x HDMI cable - 1.2 m , 1 x USB cable - 1.5 m
Mounting Kit
Included
MTBF
60,000 hour(s)
FCC, RoHS, WEEE, REACH
TAA Compliant
External power adapter
Installed Qty
2
AC 100 - 240 V
18 Watt
11.7 cm
13 cm
2.8 cm
610 g
Shipping Width
36.5 cm
Shipping Depth
19.5 cm
Shipping Height
32.5 cm
0 - 80%
FC0C StarTech.com 75 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £25.96
FC0C StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £31.89
FC0C StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £9.68
FC0C StarTech.com HDMI Over IP Extender Kit - 4K In Stock £464.90
FC0C StarTech.com HDMI KVM Extender Over IP In Stock £259.01
FC0C StarTech.com HDMI Receiver Over IP In Stock £138.87
FC0C StarTech.com HDMI KVM Receiver Over IP In Stock £156.31
Price Range Ex VAT: £500 - £750
